28-Jun-2024, 05:37 PM
I have a cetus x and want to upgrade the battery what battery would you recoment
Battery for Cetus x |
28-Jun-2024, 05:37 PM I have a cetus x and want to upgrade the battery what battery would you recoment 28-Jun-2024, 06:42 PM (This post was last modified: 28-Jun-2024, 06:43 PM by Pathfinder075.) Is it the 1s or 2S model? If 1S, Tattu 1S in a size over 500mAh If 2S, Tattu 2S in a similar size or GNB 2S 660mAh HV 90C or if you are going for cheap but lots of then CNHL 2S 450mAh HV (these are cheap and you can buy them in bulk) or CNHL 2S 650mAh If 2S and it came with a BT3.0 connector you're screwed. Buy an XT30 connector and swap it out. Otherwise you are limited to BetaFPV batteries, which are generally crap. Try Not, Do or Do Not - Yoda |
The quadcopter shows that it does not hold a charge, although the battery is charged. | Aleksandr | 1 | 92 | 17-Jun-2024, 03:31 PM Last Post: Pathfinder075 | |
Help Beta85x HD with 2s Battery | nicoinco | 5 | 704 | 22-May-2024, 09:33 PM Last Post: Arango | |
Help Tinyhawk 3 Plus Freestyle - battery ph2 to bt2? | CDCMeteor75ProNewb | 5 | 469 | 22-Apr-2024, 09:31 PM Last Post: Timmyhawk 2 | |
1S Battery Settings in OSD | segler999 | 7 | 1,185 | 23-Nov-2023, 01:34 AM Last Post: segler999 | |
TH3 Freestyle battery lead upgrade | Dak_4008 | 3 | 242 | 13-Oct-2023, 08:50 PM Last Post: Rob Axel |
