20-Nov-2023, 07:44 PM
Every so often somebody in the forums or youtubes mentions that the 1S batteries in our whoops are subject to more voltage sag than, say, the 3S to 6S flight packs during flight.
In the Betaflight power and battery tab, if you set the battery to the "default" Warn at 3.5 volts and Mininum at 3.3 volts, you will be staring at annoying battery warnings pretty much the whole time. Even 4.35 LiHV batteries will sag to 3.5 or lower just after takeoff and will get down to 3.3 volts after a few more seconds of flight (BT2.0 goes longer than PH2.0). When you land the drone and disconnect the 1S battery, it recovers quickly to considerably higher voltage at rest.
This supposedly is quite normal for 1S batteries.
I tried setting my Warn to 3.1 volts and Min to 2.9 volts (as some have suggested), but when it starts warning "Voltage Low" the "Land Now" comes on within seconds, and the drone failsafes right then.
OK, that's too low.
I have now been running the Warn at 3.1 volts and Min at 3.0 volts. Now the "Voltage Low" warning comes on but I still have about 20 seconds before the "Land Now" comes on, and I can still land safely under power. Again, when disconnected the battery quickly recovers to about 3.7 volts without damage.
3S to 6S settings should probably be kept at 3.5 and 3.3 volts per cell since they don't sag as much in flight.
These little batteries delivering 12 amps is amazing.
OK, that's too low.
