  • 2 Vote(s) - 4.5 Average
7" Long Range Build -
The Chameleon arms look stiffer than the Reverb to me. I have 2507’s on my Reverb and they are about perfect, no signs of over torque on the arms. Anything bigger might cause some flexing issues, so the Chameleon sounds like a better choice.
SoCal Kaity :D
  • hugnosed_bat
I am gonna cross my fingers and hope for the best. If the motors do not work on the chameleon I will put them on something else.
[-] The following 1 user Likes Kevin2112's post:
  • hugnosed_bat
I feel you will be fine with the larger motor sizing on your Chameleon frame than the Reverb frame. Your choice is solid and the Chameleon arms are part of a solid bottom plate, they should be more rigid to handle the extra torque without flexing. Really looking forward to hearing your experiences with your build! What FC are you considering?
SoCal Kaity :D
I started doing a build series. I stoped to have a discussion about the frame. Here’s what’s I’ve gotten in so far. I will solder in the motors next. I’m having some dilemma about where to mount the gos and vtx. There’s no mounting holes on the vtx. There are 4 screws that hold the 2 boards together.
Build specs:
Armattan Chameleon 7” TI LR frame
Lumenier lux F7 ultimate
Lumenier 55-65 4-1 ESC
TBS unify pro 32HV
Frsky MXR9 OTA receiver
Brother hobby avenger 2810 1500KV
Foxeer T-Rex 1500TVL 1.7 camera
Matek M9M-5883 GPS
Various props of different pitches
Green/black toxic wire braid
[Image: LKxGI6Al.jpg]
[-] The following 2 users Like Kevin2112's post:
  • the.ronin, kaitylynn
Hi Kevin,
GPS mount made with plastic from old bottle; Picture HERE.
Cut the plastic, drill holes, use heat shrink tubing to secure the GPS, bolt to the frame.
As for mounting the GPS, I have seen zip ties used; you might also use stick on Velcro or the blue sticky tack stuff.
  • Kevin2112
(09-Mar-2021, 02:17 PM)iFly4rotors Wrote: Hi Kevin,
That’s a great idea and very light weight! I could use a green bottle to match the color scheme. Did you heat shrink the gps to the plastic? It’s a little hard to see in the picture.
(09-Mar-2021, 04:58 PM)Kevin2112 Wrote: That’s a great idea and very light weight! I could use a green bottle to match the color scheme. Did you heat shrink the gps to the plastic? It’s a little hard to see in the picture.
Hi Kevin,
Yes. I used a piece of clear heat shrink tubing {I think is about 3/4 inch ?}, slide it over the GPS and plastic, then shrink it with heat gun. The plastic that I used just happens to be from an MCT oil container, but you can use anything and any color as long as it is a decent thickness so the tubing shrinks before the plastic hits critical melt point.
Everything we buy seems to come is a plastic container, so I cut up anything I think I can use and keep in box. In addition to containers, almost everything comes in some type of plastic...some thicker than others, but each has a use. I got a new case for my cell phone and the plastic it was boxed with is flat, pretty solid, and light weight...Yeah, I kept that.
Regarding the VTX: I do not heat shrink the VTX because of the heat generated. I have used the heavy duty Velcro or zip ties. I think the sticky tack putty stuff might also be good, I intend to use some on something just to test it.
High Five
I ordered some 2mm screws and 2mm standoff kit. I can take the unity’s screws out and put longer ones in and thread stand-offs on. Then I’ll bolt the whole thing down. Yeah I’ve never heat shrinked a vtx either.
  • iFly4rotors
  6S 7" build performance analysis UglyBob 5 303 02-Jun-2024, 10:53 PM
  Long Range Setup für 2024 Kepnik 1 458 16-Mar-2024, 12:15 AM
Last Post: Phoenix.-
  5" Mid range motor sizing help B4tn 4 372 01-Mar-2024, 12:25 AM
Last Post: B4tn
  light 6-7in LR build hawk01 5 367 06-Feb-2024, 06:14 PM
Last Post: Krohsis
  5in lightweight LR build hawk01 33 1,312 21-Jan-2024, 11:23 AM
Last Post: MomoBrut
