31-May-2020, 04:53 PM
Hi all,
I'm half way through my first build - thought I'd start myself off gently and build an iFlight DC3 (with DJI) using the same components the BNF uses. So an iFlight Succex Mini F7, and an iFlight Succex Mini 40A 4-in-1 ESC.
The build seemed to go fine (although my soldering needs work), and I've successfully got the FC configured in BetaFlight with my DJI radio. However I cannot get the motors to respond in the Motors section of BetaFlight.
I've downloaded and run BLHeli Configurator and hit "Read Setup". In the log I see the output below, note the four errors like "ESC 1 read settings failed cmd_DeviceInitFlash ACK_D_GENERAL_ERROR"
So my question is, how do I go about diagnosing what might be wrong here?
Thanks for your help!
Connecting to: COM6
SERIAL: Connection opened with ID: 2, Baud: 115200
Serial port <span style="color: green">successfully</span> opened with ID: 2
MultiWii API version <span style="color: green">received</span> - <strong>1.42.0</strong>
Flight controller info, identifier: <strong>BTFL</strong>, version: <strong>4.1.7</strong>
Running firmware released on: <strong>May 28 2020 15:06:20</strong>
Board: <strong>S7X2</strong>, version: <strong>0</strong>
Reading setup
sending cmd_DeviceInitFlash 0 0
received cmd_DeviceInitFlash ACK_D_GENERAL_ERROR 0 0,0,106,4
sending cmd_DeviceInitFlash 0 1
ESC 2 read settings failed cmd_DeviceInitFlash ACK_D_GENERAL_ERROR
sending cmd_DeviceInitFlash 0 2
ESC 3 read settings failed cmd_DeviceInitFlash ACK_D_GENERAL_ERROR
sending cmd_DeviceInitFlash 0 3
ESC 4 read settings failed cmd_DeviceInitFlash ACK_D_GENERAL_ERROR
Reading setup <span style="color: green">finished</span>
Connecting to: COM6
Reading setup
