As i replaced the F4 aio in my Cinelog 25 with a F7 recently i had a spare Geprc F411 35A AIO. So lets build another small whoop.
Am still super happy with my 1st mobigital 7 build, even with a Runcam Thumb Pro, but i wanted something inbetween thus so 85mm it is ;-)
Using similar build concept as my mobigotal, but then with a carbon frame to get better stiffness and less or no jello , which was a battle i was not going to win on the plastic frame of the mobigtal.
One of the key focus points on my build was to keep a super low profile for a DJI build , even with a thumb pro on top. On most builds it goes sky high when using canopies (so super bad for balance and small gap cearance) . But by using an 85 mm frame and 40mm props (typicaly used only for 74mm frames) you get some space between the front props to drop the camera in line with the props. So you dont need a high canopy and on top a thumb pro, but the thumb pro can be mounted straight on the stack.
------ Parts list ------
Frame - Twiglet mini 2' carbon frame (selected as can hold happymodel type 3 screw mounts but also 4 screw larger motors so future flexible)
PropGuards - Cut off prop guards from mobilite 7 v3 frame (cleaned up with dremmel and spray painted with Plasti Dip 'Black & Blue')
FC/ESC - GEPRC F411 35A AIO (running BF 4.4 , esc on Bluejay 48khz)
Motors - Happymodel 1102 10000kv
VTX - Caddix Vista (un-dressed )
CAM - Caddix polar nano
RX - TBS crossfire nano rx
Antenne - Mini Immortal T and a Small UFL antenna
Props - Gemfan 40mm 3 bladed props
Mounting stuff
- Cam mount, standoffs, thumb pro mount all custom TPU
- AIO gummies and some rubber o-rings here and there.
- metal 4x m2x30mm screws for the stack column and some nuts/washers
- metal 12x m1.6x5mm longer screws to mount motors
Bat grip - ummagrip for nice snug lipo on bottom (hold lipo without strap) and some random strap
Noise - buzzer(micro)
BlingBling - led strip (missing in action in the mail still)
Total build weight - ex bat 60gram.
Fav Lipos sofar - Flywoo explorer 750Mah HV 2s and Tattu 450Mah 3s (with motor output limit at 80%)
![[Image: attachment.php?aid=9454]](https://intofpv.com/attachment.php?aid=9454)
![[Image: attachment.php?aid=9455]](https://intofpv.com/attachment.php?aid=9455)
![[Image: attachment.php?aid=9446]](https://intofpv.com/attachment.php?aid=9446)
The AIO and Vista mounting holes where all widened to fit in a column mount as all slightly different. So a bit of drilling/squeezing/filing/bending to make it all fit nicely.
Motor screws longer to fit carbon + prop guard.
Lots of TPU standoffs to make it all fit nicely.
Cam holder has (slighly) adjustable angle to fit my style
Squeezed TBS crossfire nano rx between AIO and frame
Created a simple TPU holder for my Runcam Thumb Pro
Other than that nothing special in the build process.
Software wise i copied all my settings from my Mobigital 75mm whoop (running BF4.4 betas) as same AIO and connections etc. So only adjusting the tune with some slider action
Maiden flights in my appartement did show that (with roughly) identical weight as my Mobigital , it needs higher throttle so lower flight time with same battery. Likely due to more obstructed airflow from the carbon frame arms below. Its compensated by zero jello and almost no vibrations (compared the Mobigital) because of the more rigid build.
Also the slightly wider wheelbase makes if feel more stable around the roll axis with the camera mounted on top. Super smooth small gap camera stuff , so exactly what i was looking for. And a super low profile of 30mm due to the low stack position and camera mount.
Flies great at 2S and 3s . 3s better with the camera on top.
I may at some point flip the build and make it a pusher to see if unrestricted airflow makes it a better whoop overall. Probably also going to play with different motors in the future just for the fun of it.
Anyway, some tuning and fun flying to do ;-)
edit: see later post for pusher version DigiTwig V2 which final version ended up looking like this
![[Image: attachment.php?aid=9500]](https://intofpv.com/attachment.php?aid=9500)
edit 2 : and again later here DigiTwig V3 which is the final version i settled with after a long road of modifications until i was happy. This version has front 40mm and back 2' props
Mounting stuff
