29-Jan-2017, 10:35 PM
Very strange, it must be something very simple.
Wizard 220 Help... |
29-Jan-2017, 10:35 PM Very strange, it must be something very simple. 29-Jan-2017, 10:40 PM Simple and elusive haha. I'll post screens of BF setup in a bit and see if anyone notices anything that Im just not seeing/ 29-Jan-2017, 10:46 PM (This post was last modified: 29-Jan-2017, 10:47 PM by Dutch Drone Builder.) Good idea, and keep checking your motor directions and if you use the right props. I had the first time all my props on the wrong motor, so it was pushing itself into the ground. Check also if you have used 2 CW props and 2 CCW props instead of 3 - 1. If you spin one motor in the motor tab, is it then the right motor? 29-Jan-2017, 11:41 PM Yes, the motors are spinning correct... 1 is 1, 2 is 2, etc etc and all four spin in the proper direction. i tripled check the props just to make sure I didnt over look anything and these are actually marked cw, and ccw. when spinning up the motors in BF they hold solid, it's when i connect the tx and spin up is when everything goes to hell. 30-Jan-2017, 12:07 AM Let us know if it is anything similar to the problem Im having with my stock H8 mini board. Only changed motors and props. Acts as if my roll trim is stuck until i touch down and it starts all over. Im at the point Im chucking it up to harmonic vibrations. http://intofpv.com/t-h8-mini-board-pq-fr...fting-roll Posted a video in a reply. Sorry if this is completely different. Brainstorming 30-Jan-2017, 12:43 AM Your issue kind of sort of looks similar but I believe it's a different issue. I'll try to upload a video later of it on the bench and how it reacts when given some throttle. Here are the screens from my BF setup. https://s28.postimg.org/afrq2ybnh/screen1a.jpg https://s28.postimg.org/6koc0dshp/screen2a.jpg https://s28.postimg.org/oorcl0q65/screen3a.jpg https://s28.postimg.org/x8aqiryil/screen4a.jpg https://s28.postimg.org/m9zh0l9x9/screen5a.jpg 30-Jan-2017, 12:48 AM (29-Jan-2017, 11:41 PM)anygiven60 Wrote: Yes, the motors are spinning correct... 1 is 1, 2 is 2, etc etc and all four spin in the proper direction. i tripled check the props just to make sure I didnt over look anything and these are actually marked cw, and ccw. when spinning up the motors in BF they hold solid, it's when i connect the tx and spin up is when everything goes to hell.Only thing i could think of, maybe yaw motor direction is wrong? Can be set by yaw_motor_direction in cli, but would be weird... Do motors react correct to yaw stick? 30-Jan-2017, 12:51 AM 30-Jan-2017, 02:02 AM Fingers crossed! lol 30-Jan-2017, 04:01 AM fftunes: yes the yaw stick reacts as it should. Once I give yaw then the same issue, 1 and 2 steadily increase and 3 and 4 decrease no matter which direction i give yaw. Renv08r: sorry I should have stated earlier that the 270 setting was done after my first attempt of getting lift off and after reading some other articles. First attempt the hard right yaw, second attempt AFTER the 270 setup, hard right yaw. I'll get a video posted tomorrow hopefully after work. I do appreciate the help guys, I truly do. I came from flying helis and this is a whole new beast! (30-Jan-2017, 04:01 AM)anygiven60 Wrote: fftunes: yes the yaw stick reacts as it should. Once I give yaw then the same issue, 1 and 2 steadily increase and 3 and 4 decrease no matter which direction i give yaw. Are you sure about the motor order i.e. was it just typo? With normal motor direction, for yaw stick right => motors 2&3 should engage, yaw stick left => motors 1&4 ... PS: There's a trap with board orientation... values can be positive or negative. Also the little circle-arrow-symbol is misleading in the gui, could it be your board needs +90° or -270° instead? 30-Jan-2017, 07:27 PM 30-Jan-2017, 07:30 PM (29-Jan-2017, 10:24 PM)anygiven60 Wrote: On the bench and outside. Both times I've tried to get it to lift off, it goes hard right yaw and goes straight into the grass. Can you please tell me how you fixed your x220 to work? I can't get mine to listen to my controller it is bound but doesn't work the same problem you had at the beginning of this thread 30-Jan-2017, 08:42 PM @anygiven60 one simple question, is your fc mounted normally with arrow pointing forward? 30-Jan-2017, 09:52 PM @anygiven60 could you tell me how you solved your problem with your remote control |
The GPS BN 220 lost the sat fix every time I unplug and plug in a new lipo ! | Rosssiiii | 55 | 3,581 | 02-Jan-2023, 12:59 PM Last Post: Rosssiiii | |
Eachine wizard x220 v2 setup | shahinsa | 4 | 605 | 17-Nov-2022, 09:17 AM Last Post: shahinsa | |
Motor issue on brand new Eachine Wizard X220 V2 | shahinsa | 8 | 656 | 16-Nov-2022, 01:01 PM Last Post: Rob Axel | |
Solved Wizard x220s ARF with X8R receiver (rx_failsafe) | C_Sagan_42 | 4 | 305 | 31-Oct-2022, 01:43 PM Last Post: SnowLeopardFPV | |
Betaflight won't detect BN 220 GPS | Sgtsaughter | 3 | 553 | 23-Oct-2022, 12:35 AM Last Post: kafie1980 |
