15-Oct-2018, 04:29 PM
When you strip the threads out of your motor mount just get a slightly longer screw, and a nut to secure it
Photo shared from Facebook group.
What to do with motor with stripped mounting hole? |
15-Oct-2018, 04:29 PM When you strip the threads out of your motor mount just get a slightly longer screw, and a nut to secure it Photo shared from Facebook group. When I swapped the RS2205s off one quad to another there was a bit of galvanic corrosion between the carbon steel screws and the Al housings and the housing threads were toast. I used A304 M3 x 3mm helicoils (50 cents each) and re-tapped them with a Dremel and a 3.15mm bit (needs the work stand). The above is even easier, but doesn't work on closed housings |
An easy way to solder to motor pads with slots | Rob3ddd | 5 | 775 | 08-Jan-2023, 02:54 PM Last Post: iFly4rotors | |
Is there an easy way to use a stepper motor instead of a servo? (via taranis or FC) | salukikev | 1 | 3,255 | 01-Feb-2021, 06:19 PM Last Post: EVILsteve | |
Tutorial Fixing stripped mounting holes in camera case | sirdude | 16 | 2,901 | 13-Feb-2019, 11:38 AM Last Post: sirdude | |
Motor Brushless motor winding and rewinding | DzikuVx | 8 | 6,907 | 11-Feb-2018, 10:48 PM Last Post: Dronenut | |
Motor Brushless Motor Care | Gr8Stog | 5 | 2,707 | 27-Oct-2017, 04:42 PM Last Post: Gr8Stog |
