Threads: 4
Likes Received: 1 in 1 posts
0 I got a HGLRC 'Zeus' 350mW vtx and was looking for the Betaflight tables for it. When I go to HGLRCs website looking fo the table, it says to click 'here', and when I do, I get
PAGE NOT FOUND.
Does anyone have the table for this vtx? I would much appreciate it if you could post it here.
Threads: 18
Likes Received: 48 in 45 posts
3 Another thing about the Zeus5 board. Mine came with the wrong firmware onboard. It had a NeutronRC firmware, while their documentation mentions a HGLRC....1280 firmware. With NeutronRC there was no accelerometer. When I forced BF to flash the correct firmware, voila, I had an accelerometer again. Then, like yours, it had no vtx table.
Analog vtx tables are pretty much universal with standard frequencies in almost all cases. You can pretty much CLI any of them in and they will work. I took mine from a HGLRC Specter I have. Works fine.
You do have to pay attention to the powerlevels and powervalues. Since the Zeus5 vtx is Tramp, both powerlevels and powervalues are the same numbers. If your vtx is one of the versions of SmartAudio, those powerlevels and powervalues use different systems. SmartAudio 2.1 makes the most sense since it uses dB to set power. Oscar's article shows it all best.
Threads: 4
0 Also, I have the lost drone beep set to the loudest level. But the motors get very hot sitting on my bench not running. Is that normal?
Threads: 18
3 Yes. Beeping will really heat up a motor since it does not turn with normal airflow inside.
