Despite having my OSD settings correct for HD video, items that should be at the upper-left in my goggles appear shifted down and to the right:
Above, I've got the output of my goggles connected to a monitor (if I look in the goggles, I see the same layout as on the monitor - there's no discrepancy between the two). In BF Configurator, the CRAFT_NAME element is at the absolute upper-left but in the goggles, it appears down and to the right of this position.
Here are my settings:
I do not have osd_canvas_width or osd_canvas_height set (but I did try setting them - while this changed the size of the screen displayed in BF Configurator, it didn't change the point on the screen that's treated as upper-left).
I know that BF 4.3 didn't really support HD setups and there were various tricks (like FakeHD) to let you layout things when using a pair of HD goggles but I thought with 4.4 things should work as expected.
I've attached a full backup of my settings in case you think I might have missed something.
The firmware on the VTX and the goggles is the latest available - 33.39.10 - and the VTX is the normal V2 version (i.e. not the mini or anything unusual).
serial 0 131073 115200 57600 0 115200
# master
set osd_craft_name_pos = 2048
set osd_displayport_device = MSP
set vcd_video_system = HD
