Threads: 49
Likes Received: 192 in 157 posts
Likes Given: 186
11 16-May-2021, 07:12 PM (This post was last modified: 16-May-2021, 07:25 PM by Kevin2112.) Hello everyone:
Finally the Chameleon TI 7" is ready for programing! So when I built my last quad I manually entered the VTX tables which was painstakingly a long process. Isn't there a way to copy and paste? In the US so the 40 channel with the 3 at 0 table would work fine.
EDIT. Hey Hugs. Its a TBS unify pro32 hv sorry forgot this small tidbit as I'm supper excited, been a while to get this thing done!
Threads: 172
Likes Given: 4,724
100 # vtxtable
vtxtable bands 5
vtxtable channels 8
vtxtable powerlevels 4
vtxtable powervalues 0 1 2 3
vtxtable powerlabels 25 200 500 800
save"
Threads: 125
Likes Given: 99
388 16-May-2021, 07:17 PM (This post was last modified: 16-May-2021, 07:47 PM by voodoo614.) Yes, just copy into CLI commands. Do not use the GUI.
Threads: 38
Likes Given: 430
118 In the CLI type version and tell us what BF version does it report back. The were no vtx tables prior to 4.1 (iirc).
Also ensure you have the peripherals for the relevant uart set to TBS smart audio and click save.
Threads: 49
Likes Given: 186
11 Ha you nailed it, the FC came with 3.56 but I'm using config 10.7. Thanks, I thought since I just ordered it would have come with a newer version.
Threads: 49
Likes Given: 186
11 So flashed the up to date firmware and it flies great. I knew it had to be something simple. Thanks for all your help peeps!
