19-Sep-2020, 09:39 PM
This build all started when I added a 200mw vtx to my mobula7. However later I changed from the 2xph2.0 to an xt30 which fried the board. A week later got a 2-4s rated crazybee board to replace however it came with weird issues (quad kept flipping out of the air mid flight and eventually couldn't take off). I showed RDQ the problem and they sent me a new one free of charge (I guess you can never fully trust happymodel). Here is the final build of my take on a power whoop. I knew I wanted a 200mw vtx so I decided to stick with SPI and opted out on a buzzer for weight however I may add one in the future. Overall it flies really well and it is very smooth, no vibrations. It's a little on the heavy side but it's actually really fast and acrobatic. I'll try to get a vid once my dvr works.
Parts:
- Frame: mob7 v3
- Canopy: Aftermarket mob7 canopy for caddx eos2
- Props: gemfan 4 bladed 40mm
- Motors: betafpv 1102 13500kv
- FC: crazybee f4 v3 (2-4s)
- VTX: geprc vtx200
- Cam: caddx eos2
Extra Info:
- 525 mah 2s bat (I like longer flight times)
- props out
- FrSky
- Flight time: 3 min (lands at 3.8/cell) This thing is power hungry
- Weight w/out battery: 38 grams
Ended up adding this weird ufl connecter support because it popped off in a crash once...luckily I unplugged the battery before anything got damaged phew. Anyway, it works and only adds 0.5 gram.
I'm still flying it around and seeing what this is capable of and what improvements it needs. But so far no complaints!
Parts:
- Frame: mob7 v3
- VTX: geprc vtx200
- Cam: caddx eos2
Extra Info:
- props out
- FrSky
