Posts: 88 Threads: 39 Likes Received: 5 in 4 posts Likes Given: 0 Joined: Mar 2016 Reputation: 0 I see that most people have disabled Accelerometer on the flight controller. The question I have is when doing disabling those then you can only fly in rate mode right... but how dose it help the FC or what's the point of disabling ACC? • Posts: 55 Threads: 24 Likes Received: 6 in 5 posts Likes Given: 3 Joined: Feb 2016 Reputation: 1 Yes, you can only fly in rate mode if you turn ACC off. You have to do it on any F1 flight controller to open up space in the processor so you can run lower looptimes lower than 1000. It increases the speed that the processor can run. 1000 looptime is the lowest it can run without disabling acc. You are correct, it can only fly in acro when you do this. Posts: 2 Threads: 0 Likes Received: 0 in 0 posts Likes Given: 1 Joined: Nov 2016 Reputation: 0 19-Nov-2016, 04:31 PM (This post was last modified: 19-Nov-2016, 05:02 PM by solots.) hi like to know if your have to chance the looptime also in LCI ore only eerst dump Enter set acc_hardware = 0 dan save Enter after this input i say in cli stil 2000 looptime • Posts: 1,070 Threads: 70 Likes Received: 742 in 378 posts Likes Given: 577 Joined: Jan 2016 Reputation: 44 (13-Apr-2016, 12:08 AM)SonicCopter Wrote: Yes, you can only fly in rate mode if you turn ACC off. You have to do it on any F1 flight controller to open up space in the processor so you can run lower looptimes lower than 1000. It increases the speed that the processor can run. 1000 looptime is the lowest it can run without disabling acc. You are correct, it can only fly in acro when you do this. Probably just bad wording - it doesn't increase the processor speed. It just frees some computing power and since guys flying acro exclusively don't use the acc at all it is just wasted "resource" that can go elsewhere - to get higher looptimes in most cases. • Posts: 626 Threads: 96 Likes Received: 531 in 218 posts Likes Given: 188 Joined: May 2016 Reputation: 20 plus if you ever get stuck in a tree you'll be able to rearm your quad and try to spin the props to get out. • Posts: 1,290 Threads: 67 Likes Received: 713 in 473 posts Likes Given: 1,216 Joined: Mar 2016 Reputation: 23 (20-Nov-2016, 01:29 AM)JimmyLe813 Wrote: plus if you ever get stuck in a tree you'll be able to rearm your quad and try to spin the props to get out. No one here better qualified to make that statement then Jimmy!! "Damn the torpedoes!!! Full speed ahead!!!" Posts: 1,149 Threads: 50 Likes Received: 704 in 450 posts Likes Given: 1,189 Joined: Sep 2016 Reputation: 30 Even if you have enough cpu power, disabling acc can lead to a more constant looptime. Afaik in betaflight acc rate is slow but still math-intensive, it can bring hiccups when running fast looptimes. • Posts: 2 Threads: 0 Likes Received: 0 in 0 posts Likes Given: 1 Joined: Nov 2016 Reputation: 0 first / dump / Enter set acc_hardware = 0 than save / Enter so the looptime in LCI wil be lower than 2000 on a naze 32 ore just fly and have fun • Posts: 1,070 Threads: 70 Likes Received: 742 in 378 posts Likes Given: 577 Joined: Jan 2016 Reputation: 44 (22-Nov-2016, 06:08 PM)solots Wrote: first / dump / Enter set acc_hardware = 0 than save / Enter so the looptime in LCI wil be lower than 2000 on a naze 32 ore just fly and have fun You don't need to do that on betaflight - if you set lower looptime in configuration tab, additional hardware will be disabled automatically • Posts: 545 Threads: 28 Likes Received: 135 in 101 posts Likes Given: 94 Joined: Oct 2018 Reputation: 6 Sorry if I am reviving this post from the dead! Does it make sense still disabling the accelerometer in an F4 board if one flies only in acro? • Posts: 1,312 Threads: 50 Likes Received: 832 in 504 posts Likes Given: 372 Joined: Jul 2018 Reputation: 51 (11-Jul-2019, 10:32 AM)brnmd Wrote: Sorry if I am reviving this post from the dead! Does it make sense still disabling the accelerometer in an F4 board if one flies only in acro? It's probably not worth it. I can't remember my CPU usage off the top of my head but now Betaflight have ditched the higher looptimes I don't know if it's even possible to peg the CPU on F4. Maybe if you're mining cryptocurrency while flying. Or running that silly Redcat stuff. The ground is for dead people. Posts: 545 Threads: 28 Likes Received: 135 in 101 posts Likes Given: 94 Joined: Oct 2018 Reputation: 6 (11-Jul-2019, 10:36 AM)Banelle Wrote: It's probably not worth it. I can't remember my CPU usage off the top of my head but now Betaflight have ditched the higher looptimes I don't know if it's even possible to peg the CPU on F4. Maybe if you're mining cryptocurrency while flying. Or running that silly Redcat stuff. I saw a decrease of 7% on the Mamba Mini FC on CPU load just by disabling this, bear in mind that I have softserial and telemetry on. Is there a what to show current CPU load mid flight on the OSD? Haven't even looked yet though. • Posts: 21,152 Threads: 580 Likes Received: 8,913 in 6,593 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 786 Unless your CPU load is over 50% you don't even need to worry about it. I leave the accelerometer switched on because after a firmware update or after I've changed some settings I use it to do a hover test in angle mode in my back garden which is a really confined space so acro mode is a no go. After a crash I also like to do a quick LOS flight in angle mode to check that everything still works. In addition to this I'm running 8K/8K loops plus I also have SoftSerial switched on and my CPU load only peaks at 12%. As already said, an F4 board has plenty of grunt to run everything, and even more so with an F7 board. Posts: 1,070 Threads: 70 Likes Received: 742 in 378 posts Likes Given: 577 Joined: Jan 2016 Reputation: 44 11-Jul-2019, 09:34 PM (This post was last modified: 11-Jul-2019, 09:39 PM by KonradS.) Keep in mind that if you are trying some experimental features like bidirectional dshot/RPM filtering, your CPU load may jump above 50% on F4 boards. • Posts: 12,099 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 I always keep accelerometer because I always have angle mode setup. One, to do what Snow does. But angle mode is a saving grace. If you ever loose your FPV feed, switching to angle can save your quad from serious damage. |
