16-Feb-2023, 06:55 AM
Hey everyone, I'm starting in the FPV quadcopter world, and I got a NAzgul5 V2 a while ago. It worked fine, but I broke a motor and kept it away for a long time.
I finally got a new motor, succesfully installed it, updated everything, flashed bluejay, and I was configuring the drone in betaflight, step by step.
Everything was fine, but in the middle of setting it up, I plugged in the battery and when I went to plugin the USB cable and it touched the USB port, smoke came out of the Flight Controller. I instantly plugged the battery off. Nothing seemed wrong, so I kept setting it up. When I got to the Video transmission tab, I noticed the VTX wasn't working, and there was no LEDs coming from it.
I tried turning the FC on with the battery plugged in and noticed that no LEDs came up from the FC nor the VTX, but the startup sound came up. However it wouldn't connect to the radio controller, or anythying, it wouldn't arm, nothing.
However when I plug in the battery with the USB connected, everything works, I can control and arm with the radio controller, only video transmitter doesn't work, it shows no LEDs, no sign of life.
I unpplugged everything and noticed the underside of the FC is burned.
It would be great if someone could point me in the right direction to fixing it.
I read it is most likely a PDB issue, probably shorted it, but I don't know how to fix it or where to start.
Should i just get a new FC?
Is it possible the VTX is also damaged?
Thank you in advance.
Here's a video that better shows it. (the flight controller got hot after I finished recording and unplugged the battery)
this is the burnt part
