20-Oct-2023, 01:31 AM
I ordered this FC to replace my Skystars on which the 10V power (used for DJI O3) went kaput: Amazon.com: GoolRC GF30F722-ICM F722 F7 HD Baro OSD 5V 10V Dual BEC Flight Controller 3-8S 30.5X30.5mm. It doesn't connect to betaflight with just USB power, as all of my other FCs do.
I rewired the FC to ESC harness so the pins match up, connected a battery, and I got full startup tones. I then plugged in USB to betaflight, it connects, and everything looks OK with a quick check.
Is it normal for some FCs to require battery power to connect to Betaflight? Not only have I never had to do it before, but I've never seen it in any BF configuration videos I've watched, other than of course if I want to do something with the motors.
This is going to be a bit of a pain with the quad assembled, as the O3 gets quite hot with battery connected, so I have to put a fan on it whenever I do that, and I try to limit the time I have the battery connected. Or I can disconnect the O3, but that also is a bit of a hassle.
Is this just part of the deal for a cheapo FC, or is there something I'm missing?
