Tiny whip for tiny whoop
After seeing Oscar's post https://oscarliang.com/make-simple-whip-...near-polo/ about making a whip antenna for tiny whoops, I thought that sounds like a great idea. I'm always bending the cheap clover on mine. But on further inspection, I'm a bit confused...
From what I can tell, (by looking and beeping out with a meter) on the clover leaf, the core of the co-ax runs up and connects to the centre of the leaves. The leaves then connect to the shield of the co-ax, which is soldered to a different pad at the bottom.
However, on the whip antenna, the core of the wire, sticks out, at the top, and is not connected in any way to the shield.
Am I missing something here? Or why the difference in the two antenna?
Thanks for the help!
Attached Files Thumbnail(s)
No, you're not missing anything. You're just looking at two different antenna design approaches.
In the whip antenna, the unshielded center conductor is the radiator, with the shielded part of the coax acting as the balance of the antenna.  The  bullet-shaped metal piece is likely often added to better match the RF impedance of the antenna and cable.  Any mismatch will lead to some losses in what the antenna is doing for you.
The lobe antenna offers the advantage of some gain over the whip dipole, and adds a circular twist to the RF energy.  I believe the circular pattern mainly helps indoors where signal reflections can be a problem.  A receiver equipped with the same type of antenna will be more effective at receiving the primary signal than those that have been reflected off of things.
Kevin B.
Quads:
Custom 110mm FPV, NanoQX w/DX6i
Other: 3D printing (printer buildThingiverse), electronics, AVR microcontrollers
Ok thanks, so if you were to snip off the lobes and then strip back the shield to leave the correct length of the core exposed, I'd have a functioning whip?
(02-Mar-2017, 03:16 PM)bossy202 Wrote: Ok thanks, so if you were to snip off the lobes and then strip back the shield to leave the correct length of the core exposed, I'd have a functioning whip?
Yes.
Kevin B.
Quads:
  Looks like i have some issues on the tiny whoop motor Rosssiiii 24 1,356 02-Feb-2024, 02:20 AM
Last Post: [email protected]
  2022 BetaFPV F4 1S 5A Toothpick/Whoop Flight Controller W/ Built in serial RX BarqsIsGood 2 185 10-Dec-2023, 01:22 PM
  Rush tiny tank only F7 ?! niuk 11 289 25-Nov-2023, 06:35 PM
Last Post: voodoo614
  Jumping Whoop, Arming Mobula 7 + Elrs T-lite Nigels 10 576 15-Aug-2023, 11:40 PM
  Convert bt2 whoop to ph2 FPVme 12 390 23-Jun-2023, 04:29 PM
Last Post: FPVme
