Taranis stuck on first screen
Have anybody experienced having their Taranis lock on the first screen (opentx)?
Even when I try to power it off it stays on and when unplugging the lipo and restarting same thing happen.
Either bad SD card or it could be a stuck button.
I'd start by pulling out the SD card and trying it that way and if no result, remove the faceplate and test to see if any buttons are impeded.
I think I remember mine doing that when I first got it. Wound up upgrading the SD card and haven't had an issue since.
(16-Apr-2016, 01:15 PM)thomasFPV Wrote: Either bad SD card or it could be a stuck button.
I tried a new SD card.. it didn't work.
Buttons are all fine. I double checked.
still stuck...
There's a small watch type looking battery inside.
Pop it out.
Turn on your Taranis (it will work) turn it off, put the little watch battery back in...
hopefully it will solve it Smile
I had some trouble like that. Flashing a new firmware fixed it. YMMV.
Re flash the firmware as redrom suggests, my taranis had some kind of weird woopsee earlier this year, strange noise then lost bind on 3 receivers. Re flashing sorted it, but not before I'd sent it back to the seller thinking it was something broken within the tx itself
(11-Jul-2016, 08:27 AM)2strokesmoke Wrote: Re flash the firmware as redrom suggests, my taranis had some kind of weird woopsee earlier this year, strange noise then lost bind on 3 receivers. Re flashing sorted it, but not before I'd sent it back to the seller thinking it was something broken within the tx itself
This is kind of a necropost, but is exactly the same issue that I'm having.
I purchased the transmitter/pair pretty recently (3 weeks?). The system worked brilliantly for three flights, then I went to use it today and it appeared to lock on the boot screen.  I've reflashed the firmware (confirmed by a new boot screen), but it is still locked.
I have used a new SD card, when I went to flash the new firmware.
  ELRS Module with Taranis X Lite NYCDiesel 3 126 06-May-2024, 05:20 AM
Last Post: NYCDiesel
  Tip & Trick FlySky i6X + OpenTX + ELRS + INAV screen psicho100pro 9 7,898 14-Apr-2024, 09:05 AM
Last Post: psicho100pro
  BetaFPV Elrs module not loading in a taranis X7 Stumpy 2 221 31-Jan-2024, 12:19 PM
Last Post: Stumpy
  Taranis & TD 100 [km] zomer 0 203 03-Sep-2023, 03:27 PM
Last Post: zomer
  Help RSSI callout Taranis QX7/OpenTX? swequad 1 274 13-Jul-2023, 03:05 PM
