12-Apr-2021, 01:00 AM
Hey guys,
I Know I already posted this before, but I have new infos, so I deleted the older one. There goes:
I have a Nazgul5 which I was installing My receiver. After and before the instalation everything was working fine.
Then I was troubleshooting A failsafe problem, so I was pluggging the battery and the usb cable on and off the drone, testing failsafe and other stuff.
Out of nowhere I plug the battery and I saw smome coming off the underside of the FC. Went to look and there was a Short between BAT and GND on the pin side of the connector of the FC that comes from the ESC, the ESC seems to be fine(didnt tested but no apparent damage to it) The only I think could have any relation is that 2-3 times I had to plug the battery out while the drone was armed with motors running (no props) and was not entering failsafe. The only thing I changed was the 5v,gnd and signal pad. Could a short in 5v do that?
https://imgbb.com/3cMbyLT
(I tested receiver and vtx with external supply and they work fine)
