Sand and dirt in mini quad motors
Anyone get sand in their motors before? I've done it twice now.
Is there a way to take a motor apart and service it or is it just easier to keep buying new ones.
You just need to remove c clip from bottom of shaft then you can seperate magnet end from wire end.
One some motors you can take the bell off the motor usually a allen key collar. I just wash them out with water blow them out one drop of break free oil on each bearing reassemble.
Then dry them with hair dryer or under the sun.
[-] The following 1 user Likes OverDischarged's post:
  • romvesen
Until you can get the circlip off, just blowing into the motors very hard or using some compressed air will also help.
The best way is to remove the clip and bell and clean the motors, though. You can stick some duct tape onto the magnets and peel it off to get the sand out.
Sand sticks because of the metallic particles in it. Really bad Sad
Multirotor Maniac
Website => http://fpvfrenzy.com
Unless they're cobras......the tape may pull the magnets themselves out.......cobras seems to have a problem holding onto their magnates.......
  one of the motors does not arm balabushka 4 119 01-Apr-2024, 09:54 PM
  Skystars 1404 motors (any kv) Pathfinder075 16 711 14-Mar-2024, 10:56 PM
  Solved 2004 3000kv motors on 6s Mad35 6 232 12-Mar-2024, 06:05 AM
Last Post: Mad35
  YSIDO MOTORS hawk01 2 549 16-Jan-2024, 06:14 AM
Last Post: hawk01
  ESC on AIO got silent and not spinning motors. Everything else looks fine. maxer 12 444 16-Dec-2023, 10:16 AM
Last Post: maxer
