Hi. I got really stuck during my build. Board is SpeedyBee F745 AIO.
At the beginning everything was normal, except ESC beeping sequence was repeated twice for some reason. Motors were spinning OK.
Then sometimes when I connected battery I got no ESC sounds and could not spin motors using BF Configurator anymore. It was every second battery connection. Now its permanently broken.
Board connects and is visible in Betaflight OK. Web based esc-configurator.com works and shows ESCs and allows to flash it.
MOSFETs get very hot in 20 seconds after connecting battery with no load, no motors spinning. I desoldered 3 motors leaving one connected, still, all 4 groups of MOSFETS get hot.
I connect via USB cable to Mac. I was never been able to flash FC using Speedybee App, it asks to connect to FC's Wifi and then nothing happens (iOS).
I tried:
I tried:
- Downgrade BF to 4.2.11, the original version.
- Reflash ESC with BlueJay
- measured resistance on all motor connectors. No wire-to-wire shorts, no shorts between Batt + and - to any of the motor connectors
# status
MCU F745 Clock=216MHz, Vref=3.30V, Core temp=49degC
Stack size: 2048, Stack address: 0x20010000
Config size: 3986, Max available config: 32768
Gyros detected: gyro 1
GYRO=MPU6000, ACC=MPU6000, BARO=BMP280
OSD: MAX7456
System Uptime: 15 seconds, Current Time: 2023-12-04T02:26:13.793+00:00
CPU:1%, cycle time: 125, GYRO rate: 8000, RX rate: 33, System rate: 10
Voltage: 2515 * 0.01V (6S battery - OK)
I2C Errors: 9
SD card: Not configured
Arming disable flags: RXLOSS ANGLE CLI MSP
