Same Problem on both quads!
Angry I had purchased the KOPIS 1 to have a quad that I can always fly while I am building. However to make a long story short, I had to replace the KOPIS 1 FC. I put another KAKUTE F4 AIO into the KOPIS 1. However the very moment I arm the quad the motors hit full throttle and is compltely out of control. I thought it was the GYRO trying to correct itself, thought it was a bent motor. Put new ones on, did every thing suggested online and still the same problem. I returned it. In the mean time I finished a build using HGLRC F4 V5PRO. First flight, the moment I arm THE EXACT SAME THING!!!! I had used the receiver from the KOPIS 1 in this build. The reciever being FrSKY R-XSR... Can the reciver be the problem or what am I failing to do before flight?? ANY HELP would be SOOO appreciated!!! THANK YOU
Hm i'd assume either receiver channels / channel mapping or something with the protocol are not correct in configurator (betaflight?), or the fc orientation may be wrong / set wrong.
Probably need more info. You could post a dump (go to CLI, type "dump" and copy the output), maybe someone can spot something. Use the [code ] tags to wrap the dump so it doesn't take much space on the page.
It's called the Tazmanian Devil Effect. My money's on fftune's assumption that the board's orientation is wrong
(29-Nov-2017, 02:49 PM)fftunes Wrote: Hm i'd assume either receiver channels / channel mapping or something with the protocol are not correct in configurator (betaflight?), or the fc orientation may be wrong / set wrong.
Sorry for I'm not familiar with the [code] tag...
My orientation in Betaflight setup is normal too
# master
set align_gyro = DEFAULT
set gyro_lpf = OFF
set gyro_sync_denom = 1
set gyro_lowpass_type = PT1
set gyro_lowpass_hz = 90
set gyro_notch1_hz = 400
set gyro_notch1_cutoff = 300
set gyro_notch2_hz = 200
set gyro_notch2_cutoff = 100
set moron_threshold = 48
set align_acc = DEFAULT
set acc_hardware = AUTO
set acc_lpf_hz = 10
set acc_trim_pitch = 0
set acc_trim_roll = -2
set align_mag = DEFAULT
set mag_hardware = NONE
set mag_declination = 0
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
set baro_bustype = I2C
set baro_spi_device = 0
set baro_i2c_device = 2
set baro_i2c_address = 0
set baro_hardware = NONE
set baro_tab_size = 21
set baro_noise_lpf = 600
set baro_cf_vel = 985
set baro_cf_alt = 965
set min_check = 1050
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 41
set rssi_invert = OFF
set rc_interp = AUTO
set rc_interp_ch = RP
set rc_interp_int = 19
set fpv_mix_degrees = 0
set max_aux_channels = 14
set serialrx_provider = SBUS
set sbus_inversion = ON
set spektrum_sat_bind = 0
set serialrx_halfduplex = OFF
set blackbox_p_ratio = 32
set blackbox_device = NONE
set blackbox_record_acc = ON
set min_throttle = 1020
set max_throttle = 2000
set dshot_idle_value = 450
set use_unsynced_pwm = OFF
set motor_pwm_protocol = MULTISHOT
set motor_pwm_rate = 480
set motor_pwm_inversion = OFF
set thr_corr_value = 0
set thr_corr_angle = 800
set failsafe_delay = 4
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_procedure = DROP
set align_board_yaw = 0
set gimbal_mode = NORMAL
set bat_capacity = 0
set vbat_hysteresis = 1
set current_meter = ADC
set battery_meter = ADC
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set vbat_cutoff_percent = 100
set vbat_scale = 110
set ibata_scale = 400
set ibata_offset = 0
set ibatv_scale = 0
set ibatv_offset = 0
set beeper_inversion = ON
set beeper_od = OFF
set beeper_frequency = 0
set beeper_dshot_beacon_tone = 0
set yaw_motors_reversed = OFF
set servo_center_pulse = 1500
set servo_pwm_rate = 50
set servo_lowpass_hz = 0
set tri_unarmed_servo = ON
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = ON
set small_angle = 25
set disarm_kill_switch = ON
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_wp_radius = 200
set nav_controls_heading = ON
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set fixedwing_althold_reversed = OFF
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 0
set yaw_deadband = 0
set pid_process_denom = 2
set tlm_switch = OFF
set tlm_inverted = OFF
set tlm_halfduplex = ON
set frsky_default_lat = 0
set frsky_default_long = 0
set frsky_gps_format = 0
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set hott_alarm_int = 5
set pid_in_tlm = OFF
set report_cell_voltage = OFF
set osd_units = METRIC
set osd_rssi_alarm = 20
set osd_cap_alarm = 2200
set osd_alt_alarm = 100
set osd_ah_max_pit = 20
set osd_ah_max_rol = 40
set osd_tim1 = 2048
set osd_tim2 = 1537
set osd_vbat_pos = 2464
set osd_rssi_pos = 40
set osd_tim_1_pos = 2102
set osd_tim_2_pos = 2081
set osd_flymode_pos = 2445
set osd_throttle_pos = 225
set osd_vtx_channel_pos = 377
set osd_crosshairs = 2248
set osd_ah_sbar = 200
set osd_ah_pos = 2248
set osd_current_pos = 2503
set osd_mah_drawn_pos = 2510
set osd_craft_name_pos = 2090
set osd_gps_speed_pos = 218
set osd_gps_lon_pos = 82
set osd_gps_lat_pos = 65
set osd_gps_sats_pos = 51
set osd_home_dir_pos = 302
set osd_home_dist_pos = 303
set osd_compass_bar_pos = 266
set osd_altitude_pos = 247
set osd_pid_roll_pos = 423
set osd_pid_pitch_pos = 455
set osd_pid_yaw_pos = 487
set osd_debug_pos = 1
set osd_power_pos = 321
set osd_pidrate_profile_pos = 345
set osd_warnings_pos = 329
set osd_avg_cell_voltage_pos = 76
set osd_pit_ang_pos = 257
set osd_rol_ang_pos = 289
set osd_battery_usage_pos = 392
set osd_disarmed_pos = 138
set osd_nheading_pos = 311
set osd_nvario_pos = 279
set osd_esc_tmp_pos = 82
set osd_esc_rpm_pos = 83
set osd_stat_max_spd = ON
set osd_stat_max_dist = OFF
set osd_stat_min_batt = ON
set osd_stat_min_rssi = ON
set osd_stat_max_curr = ON
set osd_stat_used_mah = ON
set osd_stat_max_alt = OFF
set osd_stat_bbox = ON
set osd_stat_endbatt = OFF
set osd_stat_bb_no = ON
set osd_stat_tim_1 = OFF
set osd_stat_tim_2 = ON
set task_statistics = ON
set debug_mode = NONE
set cpu_overclock = OFF
set pwr_on_arm_grace = 5
set vtx_halfduplex = ON
set vcd_video_system = 0
set vcd_h_offset = 0
set vcd_v_offset = 0
set max7456_clock = FULL
set led_inversion = 0
set dashboard_i2c_bus = 1
set dashboard_i2c_addr = 60
It sounds like a problem with the RX so far from your description. But it could also be something else.
Do you have blackbox logger on your quad? would be useful to troubleshoot with some blackbox data.
And you could also try removing all the props on the bench, and try full throttle for a few seconds see what happen there? you can keep USB plugged in and see what goes on in the receiver tab.
  • fftunes
Like Oscar said, check the channels in receiver tab first. If it's an issue with tx/rx, it should be visible there. If the receiver gets powered by the FC when connected to USB, you don't even need the flight battery for that.
What frequency are gyro loop and PID loop set to?
Have you calibrated the escs?
  Can I bring my old quads up to date? husafreak 11 423 16-Nov-2023, 06:51 AM
Last Post: husafreak
  Problem spike on roll ADRY 3 525 17-Oct-2021, 06:17 PM
Last Post: ADRY
  ready to fly quads yasser 6 1,194 27-Sep-2021, 06:37 AM
Last Post: yasser
  Classic quads? Sphere 6 611 13-Jan-2021, 03:03 AM
Last Post: bffigjam
  A fail when testing. 2 failsafes on 2 different quads plus amp meter issue :) UrbanJungle1966 3 674 05-Oct-2019, 11:42 PM
Last Post: UrbanJungle1966
