29-Nov-2017, 10:55 AM
I had purchased the KOPIS 1 to have a quad that I can always fly while I am building. However to make a long story short, I had to replace the KOPIS 1 FC. I put another KAKUTE F4 AIO into the KOPIS 1. However the very moment I arm the quad the motors hit full throttle and is compltely out of control. I thought it was the GYRO trying to correct itself, thought it was a bent motor. Put new ones on, did every thing suggested online and still the same problem. I returned it. In the mean time I finished a build using HGLRC F4 V5PRO. First flight, the moment I arm THE EXACT SAME THING!!!! I had used the receiver from the KOPIS 1 in this build. The reciever being FrSKY R-XSR... Can the reciver be the problem or what am I failing to do before flight?? ANY HELP would be SOOO appreciated!!! THANK YOU
