RHCP VS LHCP
somewhere  i think was a range coverage chart for RHCP / LHCP
clover and the RHCP seemed to have a bit bigger range..??
anybody seen or know about the difference if any?
thanks for the illumination
LHCP and RHCP have the same range. One is right hand and one is left hand circular polarity. You want to match the same polarity antennas for VRX and VTX.
  • sirdude
https://oscarliang.com/best-fpv-antenna/#polarization
I don’t think one should have better range than the other
  • sirdude
I recently has occasion to mount both RHCP and LHCP on the same quad with identical VTX units.  I flew then through and behind a lot of obstacles and the amount of break up on both videos was about the same.  There was not enough difference (to me) to say one was  better then the  other.
(16-Dec-2017, 08:04 PM)sirdude Wrote: I recently has occasion to mount both RHCP and LHCP on the same quad with identical VTX units.  I flew then through and behind a lot of obstacles and the amount of break up on both videos was about the same.  There was not enough difference (to me) to say one was  better then the  other.
 perhaps the chart  was a overlay of a omni(pagoda?) and clover
that i saw and was confused or didn't read everything
 i checked Oscar's link(thanks boss) and have been there  quite a while back
when i started with FPV...
ok i came across it again ......
https://www.banggood.com/2PCS-MXK-5_8-GH...rehouse=CN
[-] The following 1 user Likes buzzjob's post:
  • lorentz
The images on the BG page show signal rejection of LHCP with RHCP and then the other way around... The performance looks exactly the same to me!?
  Help Best RHCP omni antenna for range and penetration pofotiou 6 1,318 30-Apr-2023, 01:02 AM
Last Post: Evaredy
  TrueRC Singularity 5.8 RHCP SMA Narsil 13 2,106 18-Apr-2020, 09:53 PM
Last Post: Narsil
  Help Difference in LHCP and RHCP antenna T18099 5 11,601 27-Oct-2016, 10:36 AM
Last Post: Grisha0
  Help Can I use RHCP antenna with LHCP antenna for FPV? indiastar 5 21,458 12-Feb-2016, 08:21 AM
Last Post: DiegoTheWolf
