Another component for my upcoming 85mm brushless build - the Racerstar 12A 4in1 that I have received from Banggood.
You can buy it here: https://goo.gl/H2WJ35
I have already used its smaller brother - the RS 4in1 6A esc and while it is still alive, another unit has ended its life by releasing the magic smoke caused by a combination of too heavy props and snow sticking onto components
This time I have decided to use 12A, because it’s just 0.5g heavier and only a bit more expensive.
Those integrated 4in1 Racerstar ESCs use BB2 chip so are able to run Blheli_S with Dshot600 and are rated for 12A with 17A peak using 2-4s lipo packs. They are using a standard 20x20mm mounting hole pattern. The holes themself are M3, but we have already learned that standard M3 spacers and nuts won’t fit perfectly - the components are packed too close to properly screw them in. Luckily, those ESCs arrive with a set of smaller nylon standoffs and there is enough of them to comfortably build the ESC-FC-top plate stack.
Wire for your lipo is already soldered onto the unit and it also arrives with two sets of signal wiring - one very short with small plugs on both ends. Second one is a longer breakout set with standard dupont plugs on one end.
Racerstar has also prepared a pretty standard 2-page BlHeli manual that is packed inside the bag.
The difference between 6A and 12A:
As stated before, the 12A version is a bit heavier at 5g, 6A weighted 4.48 (with no wires, my 6A had a bit of solder), so I’d say that 0.5g difference is negligible, taking greater Amp capabilities into account. It also uses 4 bigger gate drivers instead of circuits built from separate components (in 6A). Two more (bigger) capacitors on the underside are used to keep up with more possible noise from higher number of cells we can use.
12A version has no 5V regulator, while the 6A has one rated at 0.5A. This is not an issue, since most micro FCs we use on 2-3S have one anyway.
This product presents the same “issue” that 6A had - we have motors marked with numbers in all 4 corners and those markings are not the same that Clean/Betaflight uses - two of them need to be switched. This pattern resembles raceflights clockwise 1234 motor mixer. User needs to pay attention on wire order while soldering wires into the FC.
Pros:
Cons:
I have already written about FC for this build: Incoming:
Pros:
- Small form factor
- Full set of standoffs is provided in the package
- Dshot600 ready
Cons:
- Doesn’t accept standard sized standoffs/nuts despite having M3 mounting holes
- User needs to be extra careful of the motor order
- Racerstar 1103B 10000kv motors
- Entire 85mm brushless build
Find me on Youtube and Instagram. I currently fly: DRC Aura, NOX5R, Minimalist 112 and drive a scrap RC car
