Posts: 8 Threads: 2 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Apr 2021 Reputation: 0 Hey, I have R9M module trying to work with R9mini, both accsst and flashed with FLEX I have wired it as on picture, connecting nTX2 to S.PORT on r9mini (which is flashed with FPORT firmware) Received binds and sticks input work as long as I set serialrx_halfduplex = ON nad serialrx_inverted = ON But I have no telemetry. Setting halfduplex - OFF does not help. Any help would be much appreciated.. seting up R9M i really confusing.. • Posts: 21,294 Threads: 589 Likes Received: 8,982 in 6,647 posts Likes Given: 1,426 Joined: Jun 2018 Reputation: 789 10-Apr-2021, 12:48 PM (This post was last modified: 10-Apr-2021, 12:49 PM by SnowLeopardFPV.) It's possible that the inverter on the FC isn't working properly, or isn't a bi-directional inverter which is needed for FPORT. We've seen this on some other boards (non working inverter or design fault). What transmitter do you have, and is it an ACCST or ACCESS version? What type and version of firmware have you installed on the R9 module and receiver? When you bound to the receiver did you select one of the "TELEM On" options? Can you please also run both the "dump" and "diff all" commands in the Betaflight Configurator CLI tab and copy/paste the results back here. • Posts: 8 Threads: 2 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Apr 2021 Reputation: 0 Thanks for quick reply, Its Q7X with ACCST - flashed latest flex firmware from frsky website, R9M module is 2018 version, r9mini latest flex firmware with Fport I bind with TELEMETRY ON, radio detects two sensors: RXBt and RSSI so I hear "telemetry recovered" and have RSSI value but so battery voltage etc Running on emuflight, below is diff: DUMP: # # dump # version # EmuFlight / MATEKF411 (MK41) 0.3.3 Jan 10 2021 / 18:46:40 (467b20241) MSP API: 1.50 board_name manufacturer_id # name name Skip # resources resource BEEPER 1 B02 resource MOTOR 1 B04 resource MOTOR 2 B05 resource MOTOR 3 B06 resource MOTOR 4 B07 resource MOTOR 5 B03 resource MOTOR 6 B10 resource MOTOR 7 NONE resource MOTOR 8 NONE resource SERVO 1 NONE resource SERVO 2 NONE resource SERVO 3 NONE resource SERVO 4 NONE resource SERVO 5 NONE resource SERVO 6 NONE resource SERVO 7 NONE resource SERVO 8 NONE resource PPM 1 A03 resource PWM 1 NONE resource PWM 2 NONE resource PWM 3 NONE resource PWM 4 NONE resource PWM 5 NONE resource PWM 6 NONE resource PWM 7 NONE resource PWM 8 NONE resource LED_STRIP 1 A08 resource SERIAL_TX 1 A09 resource SERIAL_TX 2 A02 resource SERIAL_TX 3 NONE resource SERIAL_TX 4 NONE resource SERIAL_TX 5 NONE resource SERIAL_TX 6 NONE resource SERIAL_TX 7 NONE resource SERIAL_TX 8 NONE resource SERIAL_TX 9 NONE resource SERIAL_TX 10 NONE resource SERIAL_TX 11 NONE resource SERIAL_TX 12 NONE resource SERIAL_RX 1 A10 resource SERIAL_RX 2 A03 resource SERIAL_RX 3 NONE resource SERIAL_RX 4 NONE resource SERIAL_RX 5 NONE resource SERIAL_RX 6 NONE resource SERIAL_RX 7 NONE resource SERIAL_RX 8 NONE resource SERIAL_RX 9 NONE resource SERIAL_RX 10 NONE resource SERIAL_RX 11 NONE resource SERIAL_RX 12 NONE resource I2C_SCL 1 B08 resource I2C_SCL 2 NONE resource I2C_SCL 3 NONE resource I2C_SDA 1 B09 resource I2C_SDA 2 NONE resource I2C_SDA 3 NONE resource LED 1 C13 resource LED 2 C14 resource LED 3 NONE resource RX_BIND 1 NONE resource RX_BIND_PLUG 1 NONE resource SPI_SCK 1 A05 resource SPI_SCK 2 B13 resource SPI_SCK 3 NONE resource SPI_MISO 1 A06 resource SPI_MISO 2 B14 resource SPI_MISO 3 NONE resource SPI_MOSI 1 A07 resource SPI_MOSI 2 B15 resource SPI_MOSI 3 NONE resource ESCSERIAL 1 NONE resource CAMERA_CONTROL 1 NONE resource ADC_BATT 1 B00 resource ADC_RSSI 1 NONE resource ADC_CURR 1 B01 resource ADC_EXT 1 NONE resource BARO_CS 1 NONE resource PINIO 1 NONE resource PINIO 2 NONE resource PINIO 3 NONE resource PINIO 4 NONE resource OSD_CS 1 B12 resource SPI_PREINIT_IPU 1 A04 resource SPI_PREINIT_IPU 2 B12 resource SPI_PREINIT_IPU 3 NONE resource SPI_PREINIT_IPU 4 NONE resource SPI_PREINIT_IPU 5 NONE resource SPI_PREINIT_IPU 6 NONE resource SPI_PREINIT_IPU 7 NONE resource SPI_PREINIT_IPU 8 NONE resource SPI_PREINIT_IPU 9 NONE resource SPI_PREINIT_IPU 10 NONE resource SPI_PREINIT_IPU 11 NONE resource SPI_PREINIT_OPU 1 NONE resource SPI_PREINIT_OPU 2 NONE # mixer mixer QUADX mmix reset # servo servo 0 1000 2000 1500 100 -1 servo 1 1000 2000 1500 100 -1 servo 2 1000 2000 1500 100 -1 servo 3 1000 2000 1500 100 -1 servo 4 1000 2000 1500 100 -1 servo 5 1000 2000 1500 100 -1 servo 6 1000 2000 1500 100 -1 servo 7 1000 2000 1500 100 -1 # servo mix smix reset # feature feature -RX_PPM feature -INFLIGHT_ACC_CAL feature -RX_SERIAL feature -MOTOR_STOP feature -SERVO_TILT feature -SOFTSERIAL feature -GPS feature -RANGEFINDER feature -TELEMETRY feature -3D feature -RX_PARALLEL_PWM feature -RX_MSP feature -RSSI_ADC feature -LED_STRIP feature -DISPLAY feature -OSD feature -CHANNEL_FORWARDING feature -TRANSPONDER feature -AIRMODE feature -RX_SPI feature -SOFTSPI feature -ESC_SENSOR feature -DYNAMIC_FILTER feature -LEGACY_SA_SUPPORT feature RX_SERIAL feature TELEMETRY feature OSD feature AIRMODE feature DYNAMIC_FILTER # beeper beeper GYRO_CALIBRATED beeper RX_LOST beeper RX_LOST_LANDING beeper DISARMING beeper ARMING beeper ARMING_GPS_FIX beeper BAT_CRIT_LOW beeper BAT_LOW beeper GPS_STATUS beeper RX_SET beeper ACC_CALIBRATION beeper ACC_CALIBRATION_FAIL beeper READY_BEEP beeper MULTI_BEEPS beeper DISARM_REPEAT beeper ARMED beeper SYSTEM_INIT beeper ON_USB beeper BLACKBOX_ERASE beeper CRASH FLIP beeper CAM_CONNECTION_OPEN beeper CAM_CONNECTION_CLOSED beeper RC_SMOOTHING_INIT_FAIL # beacon beacon RX_LOST beacon RX_SET # map map TEAR1234 # serial serial 20 1 115200 57600 0 115200 serial 0 8192 115200 57600 0 115200 serial 1 64 115200 57600 0 115200 # led led 0 0,0::C:0 led 1 0,0::C:0 led 2 0,0::C:0 led 3 0,0::C:0 led 4 0,0::C:0 led 5 0,0::C:0 led 6 0,0::C:0 led 7 0,0::C:0 led 8 0,0::C:0 led 9 0,0::C:0 led 10 0,0::C:0 led 11 0,0::C:0 led 12 0,0::C:0 led 13 0,0::C:0 led 14 0,0::C:0 led 15 0,0::C:0 led 16 0,0::C:0 led 17 0,0::C:0 led 18 0,0::C:0 led 19 0,0::C:0 led 20 0,0::C:0 led 21 0,0::C:0 led 22 0,0::C:0 led 23 0,0::C:0 led 24 0,0::C:0 led 25 0,0::C:0 led 26 0,0::C:0 led 27 0,0::C:0 led 28 0,0::C:0 led 29 0,0::C:0 led 30 0,0::C:0 led 31 0,0::C:0 # color color 0 0,0,0 color 1 0,255,255 color 2 0,0,255 color 3 30,0,255 color 4 60,0,255 color 5 90,0,255 color 6 120,0,255 color 7 150,0,255 color 8 180,0,255 color 9 210,0,255 color 10 240,0,255 color 11 270,0,255 color 12 300,0,255 color 13 330,0,255 color 14 0,0,0 color 15 0,0,0 # mode_color mode_color 0 0 1 mode_color 0 1 11 mode_color 0 2 2 mode_color 0 3 13 mode_color 0 4 10 mode_color 0 5 3 mode_color 1 0 5 mode_color 1 1 11 mode_color 1 2 3 mode_color 1 3 13 mode_color 1 4 10 mode_color 1 5 3 mode_color 2 0 10 mode_color 2 1 11 mode_color 2 2 4 mode_color 2 3 13 mode_color 2 4 10 mode_color 2 5 3 mode_color 3 0 8 mode_color 3 1 11 mode_color 3 2 4 mode_color 3 3 13 mode_color 3 4 10 mode_color 3 5 3 mode_color 4 0 7 mode_color 4 1 11 mode_color 4 2 3 mode_color 4 3 13 mode_color 4 4 10 mode_color 4 5 3 mode_color 5 0 9 mode_color 5 1 11 mode_color 5 2 2 mode_color 5 3 13 mode_color 5 4 10 mode_color 5 5 3 mode_color 6 0 6 mode_color 6 1 10 mode_color 6 2 1 mode_color 6 3 0 mode_color 6 4 0 mode_color 6 5 2 mode_color 6 6 3 mode_color 6 7 6 mode_color 6 8 0 mode_color 6 9 0 mode_color 6 10 0 mode_color 7 0 3 # aux aux 0 0 0 900 1300 0 0 aux 1 1 1 1675 2075 0 0 aux 2 2 1 1300 1700 0 0 aux 3 13 2 1700 2100 0 0 aux 4 0 0 900 900 0 0 aux 5 0 0 900 900 0 0 aux 6 0 0 900 900 0 0 aux 7 0 0 900 900 0 0 aux 8 0 0 900 900 0 0 aux 9 0 0 900 900 0 0 aux 10 0 0 900 900 0 0 aux 11 0 0 900 900 0 0 aux 12 0 0 900 900 0 0 aux 13 0 0 900 900 0 0 aux 14 0 0 900 900 0 0 aux 15 0 0 900 900 0 0 aux 16 0 0 900 900 0 0 aux 17 0 0 900 900 0 0 aux 18 0 0 900 900 0 0 aux 19 0 0 900 900 0 0 # adjrange adjrange 0 0 0 900 900 0 0 0 0 adjrange 1 0 0 900 900 0 0 0 0 adjrange 2 0 0 900 900 0 0 0 0 adjrange 3 0 0 900 900 0 0 0 0 adjrange 4 0 0 900 900 0 0 0 0 adjrange 5 0 0 900 900 0 0 0 0 adjrange 6 0 0 900 900 0 0 0 0 adjrange 7 0 0 900 900 0 0 0 0 adjrange 8 0 0 900 900 0 0 0 0 adjrange 9 0 0 900 900 0 0 0 0 adjrange 10 0 0 900 900 0 0 0 0 adjrange 11 0 0 900 900 0 0 0 0 adjrange 12 0 0 900 900 0 0 0 0 adjrange 13 0 0 900 900 0 0 0 0 adjrange 14 0 0 900 900 0 0 0 0 # rxrange rxrange 0 1000 2000 rxrange 1 1000 2000 rxrange 2 1000 2000 rxrange 3 1000 2000 # vtx vtx 0 0 0 0 0 900 900 vtx 1 0 0 0 0 900 900 vtx 2 0 0 0 0 900 900 vtx 3 0 0 0 0 900 900 vtx 4 0 0 0 0 900 900 vtx 5 0 0 0 0 900 900 vtx 6 0 0 0 0 900 900 vtx 7 0 0 0 0 900 900 vtx 8 0 0 0 0 900 900 vtx 9 0 0 0 0 900 900 # rxfail rxfail 0 a rxfail 1 a rxfail 2 a rxfail 3 a rxfail 4 h rxfail 5 h rxfail 6 h rxfail 7 h rxfail 8 h rxfail 9 h rxfail 10 h rxfail 11 h rxfail 12 h rxfail 13 h rxfail 14 h rxfail 15 h rxfail 16 h rxfail 17 h # master set align_gyro = DEFAULT set gyro_hardware_lpf = NORMAL set gyro_32khz_hardware_lpf = NORMAL set gyro_sync_denom = 1 set gyro_lowpass_type = PT1 set gyro_lowpass_hz_roll = 180 set gyro_lowpass_hz_pitch = 180 set gyro_lowpass_hz_yaw = 30 set gyro_lowpass2_type = PT1 set gyro_lowpass2_hz_roll = 350 set gyro_lowpass2_hz_pitch = 350 set gyro_lowpass2_hz_yaw = 350 set gyro_notch1_hz = 0 set gyro_notch1_cutoff = 0 set gyro_notch2_hz = 0 set gyro_notch2_cutoff = 0 set gyro_calib_duration = 125 set gyro_calib_noise_limit = 48 set gyro_offset_yaw = 0 set imuf_roll_q = 8500 set imuf_pitch_q = 8500 set imuf_yaw_q = 3000 set imuf_w = 12 set imuf_sharpness = 2500 set gyro_overflow_detect = ALL set yaw_spin_recovery = ON set yaw_spin_threshold = 1950 set gyro_use_32khz = OFF set dynamic_gyro_notch_q = 250 set dynamic_gyro_notch_min_hz = 150 set dynamic_gyro_notch_max_hz = 600 set align_acc = DEFAULT set acc_hardware = AUTO set acc_lpf_hz = 40 set acc_trim_pitch = 0 set acc_trim_roll = 0 set acc_calibration = -123,24,-399 set baro_bustype = I2C set baro_spi_device = 0 set baro_i2c_device = 1 set baro_i2c_address = 0 set baro_hardware = NONE set baro_tab_size = 21 set baro_noise_lpf = 600 set baro_cf_vel = 985 set baro_cf_alt = 965 set mid_rc = 1500 set min_check = 1050 set max_check = 1900 set rssi_channel = 16 set rssi_src_frame_errors = OFF set rssi_scale = 200 set rssi_offset = 0 set rssi_invert = OFF set rc_interp = MANUAL set rc_interp_ch = RPYT set rc_interp_int = 21 set rc_smoothing_type = FILTER set rc_smoothing_input_hz = 50 set rc_smoothing_derivative_hz = 75 set rc_smoothing_debug_axis = ROLL set rc_smoothing_input_type = BIQUAD set rc_smoothing_derivative_type = BIQUAD set fpv_mix_degrees = 0 set cinematic_yaw = OFF set max_aux_channels = 14 set serialrx_provider = FPORT set serialrx_inverted = ON set spektrum_sat_bind = 0 set spektrum_sat_bind_autoreset = ON set airmode_start_throttle_percent = 32 set rx_min_usec = 885 set rx_max_usec = 2115 set serialrx_halfduplex = ON set show_altered_rc = OFF set adc_device = 1 set input_filtering_mode = OFF set blackbox_p_ratio = 32 set blackbox_device = NONE set blackbox_record_acc = ON set blackbox_mode = NORMAL set min_throttle = 1070 set max_throttle = 2000 set min_command = 1000 set dshot_idle_value = 450 set dshot_burst = OFF set use_unsynced_pwm = OFF set motor_pwm_protocol = DSHOT600 set motor_pwm_rate = 480 set motor_pwm_inversion = OFF set motor_poles = 14 set thr_corr_value = 0 set thr_corr_angle = 800 set failsafe_delay = 10 set failsafe_off_delay = 10 set failsafe_throttle = 1000 set failsafe_switch_mode = STAGE1 set failsafe_throttle_low_delay = 100 set failsafe_procedure = DROP set align_board_roll = 0 set align_board_pitch = 0 set align_board_yaw = 0 set gimbal_mode = NORMAL set bat_capacity = 0 set vbat_max_cell_voltage = 43 set vbat_full_cell_voltage = 41 set vbat_min_cell_voltage = 30 set vbat_warning_cell_voltage = 34 set vbat_hysteresis = 1 set current_meter = ADC set battery_meter = ADC set vbat_detect_cell_voltage = 30 set use_vbat_alerts = ON set use_cbat_alerts = OFF set cbat_alert_percent = 10 set vbat_cutoff_percent = 100 set vbat_lpf_period = 35 set ibat_lpf_period = 10 set force_battery_cell_count = 0 set vbat_scale = 110 set vbat_divider = 10 set vbat_multiplier = 1 set ibata_scale = 210 set ibata_offset = 0 set ibatv_scale = 0 set ibatv_offset = 0 set beeper_inversion = ON set beeper_od = OFF set beeper_frequency = 0 set beeper_dshot_beacon_tone = 1 set yaw_motors_reversed = ON set crashflip_motor_percent = 0 set crashflip_power_percent = 70 set 3d_deadband_low = 1406 set 3d_deadband_high = 1514 set 3d_neutral = 1460 set 3d_deadband_throttle = 3 set 3d_limit_low = 1000 set 3d_limit_high = 2000 set 3d_switched_mode = OFF set servo_center_pulse = 1500 set servo_pwm_rate = 50 set servo_lowpass_hz = 0 set tri_unarmed_servo = ON set channel_forwarding_start = 4 set reboot_character = 82 set serial_update_rate_hz = 100 set accxy_deadband = 40 set accz_deadband = 40 set acc_unarmedcal = ON set imu_dcm_kp = 2500 set imu_dcm_ki = 7 set small_angle = 180 set auto_disarm_delay = 5 set gyro_cal_on_first_arm = OFF set use_stick_arming = OFF set gps_provider = NMEA set gps_sbas_mode = AUTO set gps_auto_config = ON set gps_auto_baud = OFF set gps_ublox_use_galileo = OFF set gps_rescue_angle = 32 set gps_rescue_initial_alt = 50 set gps_rescue_descent_dist = 200 set gps_rescue_ground_speed = 2000 set gps_rescue_throttle_p = 150 set gps_rescue_throttle_i = 20 set gps_rescue_throttle_d = 50 set gps_rescue_velocity_p = 80 set gps_rescue_velocity_i = 20 set gps_rescue_velocity_d = 15 set gps_rescue_yaw_p = 40 set gps_rescue_throttle_min = 1200 set gps_rescue_throttle_max = 1600 set gps_rescue_throttle_hover = 1280 set gps_rescue_sanity_checks = RESCUE_SANITY_ON set gps_rescue_min_sats = 8 set deadband = 0 set yaw_deadband = 0 set yaw_control_reversed = OFF set pid_process_denom = 1 set runaway_takeoff_prevention = ON set runaway_takeoff_deactivate_delay = 500 set runaway_takeoff_deactivate_throttle_percent = 20 set tlm_inverted = OFF set tlm_halfduplex = ON set frsky_default_lat = 0 set frsky_default_long = 0 set frsky_gps_format = 0 set frsky_unit = IMPERIAL set frsky_vfas_precision = 0 set hott_alarm_int = 5 set pid_in_tlm = OFF set report_cell_voltage = OFF set ibus_sensor = 1,2,3,0,0,0,0,0,0,0,0,0,0,0,0 set smartport_use_extra_sensors = OFF set ledstrip_visual_beeper = OFF set ledstrip_grb_rgb = GRB set osd_units = METRIC set osd_warn_arming_disable = ON set osd_warn_batt_not_full = ON set osd_warn_batt_warning = ON set osd_warn_batt_critical = ON set osd_warn_visual_beeper = ON set osd_warn_crash_flip = ON set osd_warn_esc_fail = ON set osd_task_frequency = 60 set osd_warn_core_temp = ON set osd_warn_rc_smoothing = ON set osd_warn_dji = OFF set osd_lq_format = TBS set osd_lq_alarm = 70 set osd_rssi_alarm = 20 set osd_cap_alarm = 2200 set osd_alt_alarm = 100 set osd_distance_alarm = 0 set osd_esc_temp_alarm = -128 set osd_esc_rpm_alarm = -1 set osd_esc_current_alarm = -1 set osd_core_temp_alarm = 70 set osd_stat_show_cell_value = OFF set osd_ah_max_pit = 20 set osd_ah_max_rol = 40 set osd_logo_on_arming = OFF set osd_logo_on_arming_duration = 5 set osd_tim1 = 2560 set osd_tim2 = 2561 set osd_vbat_pos = 2413 set osd_rssi_pos = 2316 set osd_crsf_tx_pos = 234 set osd_crsf_snr_pos = 234 set osd_crsf_rssi_pos = 234 set osd_tim_1_pos = 2379 set osd_tim_2_pos = 234 set osd_remaining_time_estimate_pos = 234 set osd_flymode_pos = 234 set osd_g_force_pos = 234 set osd_throttle_pos = 234 set osd_vtx_channel_pos = 2442 set osd_crosshairs_pos = 205 set osd_ah_sbar_pos = 206 set osd_ah_pos = 78 set osd_current_pos = 234 set osd_mah_drawn_pos = 2309 set osd_craft_name_pos = 2048 set osd_gps_speed_pos = 234 set osd_gps_lon_pos = 234 set osd_gps_lat_pos = 234 set osd_gps_sats_pos = 234 set osd_home_dir_pos = 234 set osd_home_dist_pos = 234 set osd_compass_bar_pos = 234 set osd_altitude_pos = 234 set osd_pid_roll_pos = 234 set osd_pid_pitch_pos = 234 set osd_pid_yaw_pos = 234 set osd_debug_pos = 234 set osd_power_pos = 234 set osd_pidrate_profile_pos = 234 set osd_warnings_pos = 2345 set osd_avg_cell_voltage_pos = 2407 set osd_pit_ang_pos = 234 set osd_rol_ang_pos = 234 set osd_battery_usage_pos = 234 set osd_disarmed_pos = 234 set osd_nheading_pos = 234 set osd_nvario_pos = 234 set osd_esc_tmp_pos = 234 set osd_esc_rpm_pos = 234 set osd_rtc_date_time_pos = 234 set osd_adjustment_range_pos = 234 set osd_mah_percent_pos = 234 set osd_core_temp_pos = 234 set osd_stat_rtc_date_time = OFF set osd_stat_tim_1 = OFF set osd_stat_tim_2 = ON set osd_stat_max_spd = ON set osd_stat_max_dist = OFF set osd_stat_min_batt = ON set osd_stat_endbatt = OFF set osd_stat_battery = OFF set osd_stat_min_rssi = ON set osd_stat_max_curr = ON set osd_stat_used_mah = ON set osd_stat_max_alt = OFF set osd_stat_bbox = ON set osd_stat_bb_no = ON set task_statistics = ON set debug_mode = NONE set rate_6pos_switch = OFF set cpu_overclock = OFF set pwr_on_arm_grace = 5 set vtx_band = 4 set vtx_channel = 4 set vtx_power = 4 set vtx_low_power_disarm = ON set vtx_freq = 5800 set vtx_pit_mode_freq = 0 set vtx_halfduplex = ON set vcd_video_system = NTSC set vcd_h_offset = 0 set vcd_v_offset = 0 set max7456_clock = DEFAULT set max7456_spi_bus = 2 set displayport_msp_col_adjust = 0 set displayport_msp_row_adjust = 0 set displayport_max7456_col_adjust = 0 set displayport_max7456_row_adjust = 0 set displayport_max7456_inv = OFF set displayport_max7456_blk = 0 set displayport_max7456_wht = 2 set esc_sensor_halfduplex = OFF set esc_sensor_current_offset = 0 set led_inversion = 0 set dashboard_i2c_bus = 1 set dashboard_i2c_addr = 60 set camera_control_mode = HARDWARE_PWM set camera_control_ref_voltage = 330 set camera_control_key_delay = 180 set camera_control_internal_resistance = 470 set camera_control_inverted = OFF set pinio_config = 1,1,1,1 set pinio_box = 255,255,255,255 set usb_hid_cdc = OFF set rcdevice_init_dev_attempts = 6 set rcdevice_init_dev_attempt_interval = 1000 # profile profile 0 set dterm_lowpass_type = PT1 set dterm_lowpass_hz_roll = 200 set dterm_lowpass_hz_pitch = 200 set dterm_lowpass_hz_yaw = 160 set dterm_lowpass2_hz_roll = 300 set dterm_lowpass2_hz_pitch = 300 set dterm_lowpass2_hz_yaw = 300 set smart_dterm_smoothing_roll = 50 set smart_dterm_smoothing_pitch = 50 set smart_dterm_smoothing_yaw = 10 set witchcraft_roll = 0 set witchcraft_pitch = 0 set witchcraft_yaw = 0 set pid_at_min_throttle = ON set spa_roll_p = 110 set spa_roll_i = 85 set spa_roll_d = 110 set spa_pitch_p = 110 set spa_pitch_i = 85 set spa_pitch_d = 110 set spa_yaw_p = 145 set spa_yaw_i = 70 set spa_yaw_d = 100 set acc_limit_yaw = 0 set acc_limit = 0 set crash_dthreshold = 50 set crash_gthreshold = 400 set crash_setpoint_threshold = 350 set crash_time = 500 set crash_delay = 0 set crash_recovery_angle = 10 set crash_recovery_rate = 100 set crash_limit_yaw = 200 set crash_recovery = OFF set iterm_rotation = ON set iterm_relax_cutoff = 11 set iterm_relax_cutoff_yaw = 25 set iterm_relax_threshold = 35 set iterm_relax_threshold_yaw = 35 set iterm_windup = 70 set iterm_limit = 400 set pidsum_limit = 1000 set pidsum_limit_yaw = 400 set throttle_boost = 5 set throttle_boost_cutoff = 15 set feathered_pids = 0 set i_decay = 5 set i_decay_cutoff = 200 set emu_boost = 700 set emu_boost_yaw = 750 set emu_boost_limit = 150 set emu_boost_limit_yaw = 150 set dterm_boost = 0 set dterm_boost_limit = 0 set p_pitch = 79 set i_pitch = 90 set d_pitch = 67 set p_roll = 74 set i_roll = 85 set d_roll = 60 set p_yaw = 120 set i_yaw = 70 set d_yaw = 0 set p_angle_low = 100 set d_angle_low = 10 set p_angle_high = 35 set d_angle_high = 1 set f_angle = 40 set level_limit = 45 set angle_expo = 10 set horizon_transition = 0 set horizon_tilt_effect = 80 set horizon_strength = 15 set motor_output_limit = 100 set auto_profile_cell_count = 0 # rateprofile rateprofile 0 set thr_mid = 50 set thr_expo = 0 set rates_type = BETAFLIGHT set roll_rc_rate = 100 set pitch_rc_rate = 100 set yaw_rc_rate = 100 set roll_expo = 0 set pitch_expo = 0 set yaw_expo = 0 set roll_srate = 70 set pitch_srate = 70 set yaw_srate = 70 set das_yaw_with_roll_input = 0 set das_roll_with_yaw_input = 0 set roll_pitch_mag_expo = 0 set rate_center_sensitivity = 100 set rate_end_sensitivity = 100 set rate_center_correction = 10 set rate_end_correction = 10 set rate_center_weight = 0 set rate_end_weight = 0 set tpa_rate_p = 96 set tpa_rate_i = 175 set tpa_rate_d = 90 set tpa_breakpoint = 1350 set throttle_limit_type = OFF set throttle_limit_percent = 100 set vbat_comp_type = OFF set vbat_comp_ref = 37 set vbat_comp_throttle_level = 75 set vbat_comp_pid_level = 75 # diff all diff all # version # EmuFlight / MATEKF411 (MK41) 0.3.3 Jan 10 2021 / 18:46:40 (467b20241) MSP API: 1.50 board_name manufacturer_id mcu_id 004e001f3439510a38313437 signature # reset configuration to default settings defaults nosave # name name Skip # resources # mixer # servo # servo mix # feature feature -SOFTSERIAL # beeper # beacon beacon RX_LOST beacon RX_SET # map map TEAR1234 # serial serial 0 8192 115200 57600 0 115200 serial 1 64 115200 57600 0 115200 # led # color # mode_color # aux aux 0 0 0 900 1300 0 0 aux 1 1 1 1675 2075 0 0 aux 2 2 1 1300 1700 0 0 aux 3 13 2 1700 2100 0 0 # adjrange # rxrange # vtx # rxfail # master set gyro_lowpass_hz_roll = 180 set gyro_lowpass_hz_pitch = 180 set gyro_lowpass_hz_yaw = 30 set gyro_lowpass2_hz_roll = 350 set gyro_lowpass2_hz_pitch = 350 set gyro_lowpass2_hz_yaw = 350 set imuf_roll_q = 8500 set imuf_pitch_q = 8500 set imuf_w = 12 set acc_calibration = -123,24,-399 set baro_hardware = NONE set rssi_channel = 16 set rssi_scale = 200 set serialrx_provider = FPORT set serialrx_inverted = ON set serialrx_halfduplex = ON set blackbox_device = NONE set failsafe_delay = 10 set vbat_min_cell_voltage = 30 set vbat_warning_cell_voltage = 34 set ibata_scale = 210 set yaw_motors_reversed = ON set osd_vbat_pos = 2413 set osd_rssi_pos = 2316 set osd_tim_1_pos = 2379 set osd_vtx_channel_pos = 2442 set osd_mah_drawn_pos = 2309 set osd_craft_name_pos = 2048 set osd_warnings_pos = 2345 set osd_avg_cell_voltage_pos = 2407 set vtx_channel = 4 set vtx_power = 4 set vtx_low_power_disarm = ON set vtx_freq = 5800 set vcd_video_system = NTSC # profile profile 0 set dterm_lowpass_hz_roll = 200 set dterm_lowpass_hz_pitch = 200 set dterm_lowpass_hz_yaw = 160 set dterm_lowpass2_hz_roll = 300 set dterm_lowpass2_hz_pitch = 300 set dterm_lowpass2_hz_yaw = 300 set smart_dterm_smoothing_roll = 50 set smart_dterm_smoothing_pitch = 50 set smart_dterm_smoothing_yaw = 10 set witchcraft_roll = 0 set witchcraft_pitch = 0 set spa_yaw_p = 145 set spa_yaw_d = 100 set feathered_pids = 0 set i_decay = 5 set emu_boost = 700 set emu_boost_yaw = 750 set emu_boost_limit = 150 set emu_boost_limit_yaw = 150 set p_pitch = 79 set i_pitch = 90 set d_pitch = 67 set p_roll = 74 set i_roll = 85 set d_roll = 60 set p_yaw = 120 set d_yaw = 0 # profile profile 1 # profile profile 2 # restore original profile selection profile 0 # rateprofile rateprofile 0 set tpa_rate_p = 96 set tpa_rate_i = 175 set tpa_rate_d = 90 set tpa_breakpoint = 1350 # rateprofile rateprofile 1 # rateprofile rateprofile 2 # rateprofile rateprofile 3 # rateprofile rateprofile 4 # rateprofile rateprofile 5 # restore original rateprofile selection rateprofile 0 # save configuration save # • Posts: 21,294 Threads: 589 Likes Received: 8,982 in 6,647 posts Likes Given: 1,426 Joined: Jun 2018 Reputation: 789 You actually need the following settings to use FPORT on an FC that has an onboard inverter like the GRP-F4-12A, but you said you already tried that and it's not working which is strange. Code: set serialrx_halfduplex = OFF set serialrx_inverted = ON
This is making me think that there might be a problem with the hardware inverter on the nTX2 connection. I see that you actually have an R9MM receiver (not an R9 Mini), so move the white wire from the "S.Port/F.Port" pad to the "Inverted S.Port" pad on the receiver, and move the other end of the white wire from the nTX2 pad to the UART2_TX pad. Then also run the following CLI commands to correspond with that wiring configuration... Code: set serialrx_halfduplex = ON set serialrx_inverted = OFF
Then check to see if you then get both stick movements and telemetry. • Posts: 8 Threads: 2 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Apr 2021 Reputation: 0 10-Apr-2021, 03:41 PM (This post was last modified: 10-Apr-2021, 03:41 PM by Buartek.) / move the white wire from the "S.Port/F.Port" pad to the "Inverted S.Port" pad on the / I actually tried to connect like this at the beginning - inverted S.Port to both nTX2 and TX2 and I could not get it working - no stick inout, tried all -CLI -ON and -OFF options. I`m actually considering flashing ExpressLRS • Posts: 8 Threads: 2 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Apr 2021 Reputation: 0 I flashed both module and rx to ExpressLRS and connected to TX2 and RX2, serialrx_inverted = OFF, serialrx_inverted = OFF In works perfectly, including telemetry. If anyone has similar problem I strongly recommend changing to ExpressLRS. Just remember to NOT use the inverted pads (nT2 and nR2) • Posts: 21,294 Threads: 589 Likes Received: 8,982 in 6,647 posts Likes Given: 1,426 Joined: Jun 2018 Reputation: 789 Nice one. Yes, all the FrSky stuff is a complete mess and it creates far too many headaches and wasted hours for so many people. I think that was a good choice moving to ExpressLRS. All of the ELRS testing is showing some really promising results. • Posts: 8 Threads: 2 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Apr 2021 Reputation: 0 I agree, the whole process of flashing ExpressLRR is clearly explained on github and youtube videos, there is one firmware version for rx (no accest/eccest, fcc/eu like on frsky), and you have to connect to radio only first time you flash, after that you can update by USB throught FC using special configurator. And (as for now) it works way better than standard R9 firmware for latency and stability. • Posts: 21,294 Threads: 589 Likes Received: 8,982 in 6,647 posts Likes Given: 1,426 Joined: Jun 2018 Reputation: 789 (11-Apr-2021, 05:22 PM)Buartek Wrote: And (as for now) it works way better than standard R9 firmware for latency and stability. Yes, and ExpressLRS even outperforms TBS Crossfire, TBS Tracer and ImmersionRC Ghost which is really impressive for an open source solution. While TBS and ImmersionRC can't make use of any ExpressLRS source code in their closed source solutions, I'm sure the engineers at TBS and ImmersionRC are scouring the ELRS code to get some ideas for future version of their own firmware. As long as they don't use any part of the ELRS open source code, they could still replicate some of the same architecture and functionality as long as they rewrite the code as their own implementation. So the increasing ELRS competition may start forcing some of those other systems to become better as well which would be a win-win for everyone. • Posts: 2 Threads: 1 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Feb 2022 Reputation: 0 11-Feb-2022, 09:38 PM (This post was last modified: 11-Feb-2022, 09:39 PM by tclimber.) I have a very very similar problem on the following link, but I'm not even getting RSSI or RXvBAT showing up on my taranis X9D+ ACCST...Ive given up lol. I've looked at Elrs however I would have to do a mod to my R9M ACCST module regarding the baud rates and thats still not guaranteed to work propperly because the taranis might have issues with the baud rate as well...fml.....why must things be so complicated, I upgraded to this radio some time ago for solutions to all my problems but it has just made more, can go buy a more up to date taranis but then Im sure something else will then become a problem. https://intofpv.com/t-r9mm-accst-and-tar...-r9m-accst • |
