21-Aug-2023, 05:23 AM (This post was last modified: 21-Aug-2023, 05:24 AM by swagger00219.)
I have bought an R9M 2019 module with access version and an R9MX receiver. I am trying to connect it to Tmotor Velox F4 11 lite basically an f4 fc. should the wiring be power wires and then inverted S.Port to a TX of an uart pad, and Sbus_out to sbus pad of the fc..? also, when pressing the button and powering the receiver, both red and green LEDs lit up, showing it is in bind mode. but powering the R9M TX module with 2S lipo, then pressing the F/S button behind it while [/size]powering it up, provided the dip switches are in low power mode, i.e., both off, only solid red led glows. It is not going into bind mode where both red and green LEDs should flash. I'm trying to use this module with ppm output of a flysky fs-i6 lying around, it works perfectly itself. not currently in a state to invest in a radiomaster remote or anything compatible with the R9M with expresselrs. Can it be used standalone without any firmware flash, hopefully it came with access frsky version as it says on the label. I'm trying to repurpose the flysky i6 remote. Kindly drop some pointers to proceed.
Video - https://drive.google.com/file/d/1WacFoUk...sp=sharing
Kindly help out, I'm a total noob with radio protocols and firmware flashing. I hope this investment doesnt go to waste.
