R Band missing - TBS Unify V3
I had been using this Quad with TBS unify pro v3 for months and always use R3 / R5
Since few days ago i thought the VTX is broken bcoz i can not get any image
Checked the wiring and cable.. Seems nothing wrong
Then I autosearch via goggles got A Band and receive pictures
Checked the VTX channel via LUA Script Frsky QX7
Looks. Like vtx had been reset to
A 1 25 mw
I tried to set R 3 800 mw via QX save then
Retrying message appear and failed
Tried to set A 3 800 mw then save
It works and i can fly with it
my questions is
Is that mean my VTX broken ?
Will it matter for A band.. R BAND.. E band..?
What is the different for image connection range and clarity
Yeah, that don't sound right.
That said, it probably doesn't matter unless you're in a noisy RF environment (near cell towers, around buildings with lots of wifi, that kind of thing) or flying with other people and you need to avoid each other's frequencies. I fly solo and haven't moved off F7 ever.
In theory the band and channel should have no bearing on the power output. In reality, the power output can vary pretty wildly from one frequency to another, but you'll never know without some expensive testing equipment.
try changing it in Betaflight OSD? LUA script can be funny at times..
Tried as Oscar said.. Works perfectly
Definitely LUA script sometime error
Thanks guys
  TBS Unify Pro32 HV and SpeedyBee F405 issues Shoto 5 191 02-May-2024, 11:17 PM
  TBS Fusion vs Rapidfire vs Speedybee VRX modules at same price, which is best? Luk5569 21 1,036 09-Apr-2024, 09:03 PM
Last Post: SeismicCWave
  Announcement TBS Fusion 2.34 (Beta) Firmware Released SnowLeopardFPV 10 5,200 06-Mar-2024, 01:27 AM
  TBS UNIFY Pro32 zomer 5 286 27-Feb-2024, 10:02 AM
Last Post: cst3x6
  Help Mounting TBS Unify Pro32 duschkopf 5 961 31-Aug-2023, 08:13 AM
Last Post: duschkopf
