Question about micro motors
So I was using some 7500's on 3s and getting awesome speed on my micro. Got up to right around 70mph... but sadly they get a little too hot especially in this scorching humid weather in southeast tx.
I went down to some 6500's to see if that would help but they seem to get just as hot and I even lost some speed [Image: sad.png]
I'm thinking of getting some 4000's which should solve the heat problem right? However I'll lose a lot of speed I'm sure. So I was wondering if there was a way to make up for the loss in rpms and still keep the high speed with the same 3s batteries? Would a bigger higher pitch prop do it?
What stator size motors are you using?
To see a real gain in performance you should consider bigger prop for a lower kv motor, but that mostly depends on thw motor size.
  • kaitylynn
1105 motors
  1102 motors on a 65mm pusher? ph2t 30 655 01-May-2024, 05:23 PM
  Flight controller question again.... SeismicCWave 4 113 30-Apr-2024, 05:10 AM
  CLI Dump for HGLRC Drashark 1S 1.6inch Micro Quad Oscar 1 628 23-Apr-2024, 08:08 PM
Last Post: segler999
  Ordered the HDZERO mob6 with the eco camera and 28k motors Rob Axel 35 1,124 21-Apr-2024, 06:25 PM
  Build 1106 motors on 4S for a 2" prop mstc 10 233 19-Apr-2024, 06:30 PM
