17-Apr-2024, 05:49 PM
Typically I prefer lightweight and even slightly underpowered builds as it suits my flying better. But clearly I have been influenced by several fellow forum members who seem to favor big oversized motors. I did buy a very old used Betafpv 95x that also runs 1106 motors on 4S but driving 2.5" props. After removing the ducts and putting in a lighter Walksnail 1S VTX, I was surprised that I actually enjoy flying it a lot. At around 80g dry, it gives an incredible thrust-to-weight performance. I picked up a set of T-motor 1106 when RotorRiot had them on sale (as they sell them with motor plugs) and was thinking I'd swap it into the 95X when the Betafpv motors gave out.
But I can't bear to see parts laying around, and was overcome by the urge to put them in a build. I did not have a 2.5" frame I wanted to use, but I did have a OddityRC XI20 whoop frame I've been wanting to try. 2" props sound a little small, but I figured if it doesn't work out, I'll just swap out to a 2.5" frame later.
Although they still look like tiny motors, 1106 have 3x the stator volume of a typical 2" prop motor (ie 1102) and come pretty close to a 1404. These are the T-motor M1106 6000kv motors. In my experience the F series performs better, their M series seems more budget, less smooth, less efficient, and less durable... but we'll see.
For the AIO, I am using the HM CrazyF411 ELRS off the Crux35v2. Not my favorite AIO, but come with motor plugs soldered so a good match for this setup. There is nearly nowhere to solder a digital VTX, you have to tap the power off the battery lead itself. I added a SH1.0 plug with breakout board to make connecting the VTX easier.
While I was testing the motors, I noticed that ESC1 would randomly cut-out and reboot. Because I had to fit the cap, battery lead, and VTX power all on one tiny pad, the soldering was a little bulgy. I saw that the solder joint came very close to an adjacent mosfet, but it was not bridged. I suspect this caused the ESC issues. I resoldered the lead a little tidier and covered with some liquid tape. The ESC now seems to be running fine (fingers crossed).
For the VTX, thinking to put in a naked vista, although maybe a lighter WS VTX makes more sense and will at least have 1080p onboard recording. The camera mount is nice and forward, so also good for the WS wide FOV. May swap it out later, the VTX just mounts to the bottom plate so is easy to swap.
The prop guard ring weighs around 16g... hmmm maybe go ductless too? Without the ducts, it actually fits 2.5" props. But I think I'll fly it with the prop guard first and see how it does. The dry weight will probably be close to 100g through so we'll see...
