Threads: 581
Likes Received: 8,920 in 6,599 posts
Likes Given: 1,425
786 It sounds to me like you either have a hardware issue with the Mamba MK4 H743 V2 FC, or Betaflight just doesn't yet have the correct driver support for the particular barometer it is making use of. Did you end up raising a GitHub issue for it?
Threads: 60
Likes Received: 1,003 in 728 posts
Likes Given: 96
52 I believe in your original post you mentioned you had a Geprc M10 GPS module, and that comes with a magnetometer and barometer on the module. If you connected the SDA SCL pins then you should be able to use that barometer, however not sure how BF handles multiple baros. If you do want to use that baro then you would need the custom define BARO_DPS310 for 4.4.
Threads: 7
Likes Received: 5 in 5 posts
Likes Given: 19
0 A quick update on this. I have raised a GitHub and one of the developers suggested when I connect FC to BetaFlight to also power it up and then restart it. That was the only sequence that made that FC to detect a Baro. However, the values were way off, and clearly, something was wrong with it. I did not quite understand what was different in that sequence why needed to be powered it up and then restarted it.
Anyway, I managed to find the same FC somewhere in stock so I've ordered a new one. The new one shows Baro no problem when connected to USB - C with the same BF version (no need to power it up or restart it). So I'm going to replace the old one and test again if the alt values make sense and if GPS rescue works.
