(02-Apr-2024, 03:34 PM)FPVme Wrote: Double check that your motors are all running in the correct direction. Flipping over on takeoff is frequently because one or more motors are moving in the wrong direction.
Hello FPVme,
of course the first thing I did is to check in depth the 4 motors.
As I wrote in my previous message, I have checked the behavior of the 4 motors after pulling apart their propellers...
I copy below my previous query for you to know exactly what I wrote.
I think that the culprit of such a behavior is lurking somewhere that I didn't identify so far.
Thank you for your help
Below is my previous message
Hello everyone,
my drone behaves very curiously when taking off.
In fact, when taking off it quickly tips to one side: it never takes off correctly.
Please watch my short video by clicking on this link:
https://mega.nz/file/KUJUDBjL#SzkNNW5gdy...UgF8gOo-6I To locate the origin of this fault I removed the propellers and reproduced the takeoff sequence.
I accelerated the throttle as if for a takeoff then I grabbed the drone by tilting it on one side as it does when it is equipped with propellers: the motors correct the tilt of the drone that I cause manually.
This implies that the flight controller functions correctly and corrects the position of the drone in accordance with the orders given by the transmitter.
Question is: why does the correction made without the propellers not occur when the drone is equipped with its propellers at the time of takeoff?
The flight controller is a MATEK F405 V3 card (SpeedyBee F405 V3 Flight Controller)
The motors are A2212/13T 1000KV
The propellers are 1045
The transmitter/receiver assembly is a RadioLink T8FB (8-Channel Remote Controller)
The skeleton of the drone is "X" shaped, made of carbon fiber with a distance of 400mm between each motor
The drone is an X-Quad
All parts are new and have been purchased from quality suppliers.
The programming of the flight controller was carried out by BetaFlight "betaflight-configurator_10.9.0_win64".
The behavior of the drone when taking off is incomprehensible.
I have changed the PID coefficients several times but this has no effect on the behavior of the drone when taking off.
Any help is greatly requested
