Quad fall of the sky when doing small throttle move
Hello,
After a crash my quad fall of the sky when doing small throttle move.
I was thinking of a esc desyn but the same thing append when rpm filter is disable in betaflight 4.0.
Thank you for your help
Attached Files Thumbnail(s)
.zip   log.zip (Size: 1.33 MB / Downloads: 69)
rpmfilter hasnt a special relation to desync, it wont solve anything and it might not be the source either.
it sounds like a motor, esc or power supply issue.
does it fall over the same axies all the time?
if yess, switch two motors - if it changes the axies its the motor if not it might be the esc
if it is various, check the condensator, power lead..
(28-Aug-2023, 04:38 PM)hugnosed_bat Wrote: rpmfilter hasnt a special relation to desync, it wont solve anything and it might not be the source either.
It is various, i changed xt60, condensator, redo the upload of betaflight 4.4.0 with default settings, re-flash bluedjay with default settings. but it doesn't change anything  Cry .
In the log i see a voltage drop just before.
I don't know what to check. Is it a bad ESC ? or it can a be a bad motor ?
actual bluejay has some issues, step back to the previous version go sort that out as issue
https://intofpv.com/t-don%E2%80%99t-use-bluejay-v0-20
check the frame stiffness, any arm less rigid?
anything moving?
connection well between esc and fc?
can you provide a dvr?
  • Lemonyleprosy
(31-Aug-2023, 10:13 PM)hugnosed_bat Wrote: actual bluejay has some issues, step back to the previous version go sort that out as issue
anything moving?
Yes i'm using blujay v0.19.2
I check the frame and every thing is ok, nothing is moving.
I don't have connection between esc and fc beacause i have an AIO.
Video : https://www.transfernow.net/dl/20230901n...X/ZCRhwVoN
that doesnt look like a desync issue, it would freakout and do a few flips.
an dvr with osd could maybe help, was it maybe a ruanawayprotection feature?
what aio, motors and battery do you use?
(03-Sep-2023, 12:08 PM)hugnosed_bat Wrote: that doesnt look like a desync issue, it would freakout and do a few flips.
I will post a DVR.
It happens every time i increase the throttle quickly.
How can i know if it is a runaway protection feature?
aio : HAKRC F722 40A AIO
motors: axisflying c204 2910kv
propellers : Gemfan D76-5
battery : CNHL BLACK SERIES - 1300MAH 6S 100C
osd warnings would display: "runaway"
(04-Sep-2023, 09:19 AM)hugnosed_bat Wrote: osd warnings would display: "runaway"
I don't have this warning.
I think i will order a new AIO and try if it fix
it might be one broken fet of two on one esc, but various axies doesnt match that.
hopefully the aio is the issue than
I changed the AIO by the ARGUS F7 AIO, but it's worse. know when i increase the throttle the quad go away on the side. Is it a bad AIO ?
.zip   btfl_003.zip (Size: 380.2 KB / Downloads: 22)
you changed the aio? and got even worse result?
i wasnt able to watch the vid again over the link above
  Discussion Who's Got the Heaviest 5" Freestyle Quad? SnowLeopardFPV 9 5,372 26-Jan-2024, 12:18 PM
Last Post: hawk01
  ESC How big or small Titanv11 30 4,666 04-Jan-2024, 12:27 PM
Last Post: iFly4rotors
  Build Rescue Quad iFly4rotors 177 13,642 09-Nov-2023, 09:57 PM
  Build What motors for 4" power quad? romangpro 30 2,391 21-Sep-2023, 02:26 AM
Last Post: romangpro
  Discussion 3D printed 6" freestyle quad ( WITH STLs! ) SuryaKK 13 727 24-Jul-2023, 09:30 PM
Last Post: Marcelo
