Prop noise when releasing throttle
Alright so I'm hearing a sort of rattling sound when I release the throttle after a quick burst. There's no indication of this in the controls when flying. I only noticed it in the Gopro footage. Think this is anything to be concerned about?
The video is below and here's my build thread for the parts list: https://intofpv.com/t-i-ve-decided-to-bu...th-machine
Thanks!!
Edit: Most noticeable at the 0:30 mark
how does it sound in reality? kind of metalic noise?
i would aim the esc as source if so
(17-Jul-2023, 03:28 AM)hugnosed_bat Wrote: how does it sound in reality? kind of metalic noise?
Just flew again to test it... No not really metallic sounding. I have only one battery strap that I'm absolutely positive is not making contact with a prop, but if you could imagine a prop barely making contact with a battery strap, that's about how it sounds when I am close enough to hear.
Sounds like something rattling against the mic to me
we need more information, maybe a video of a losflight with good audio?
Update: another video. Looks like it is only when I pitch or roll, not when I throttle up. definitely not something on the mic, props not making contact with anything.
https://www.youtube.com/shorts/j-h2Ve2RlaU
I FIGURED IT OUT!!!
When I built the quad, I used the SupaFly preset tune in Betaflight. When selecting this preset, there's an option to select a receiver and I selected ELRS. Wellllllll, it clearly states that its ELRS at 500hz, however my Boxer is set to 1000hz. This excess non-audible-noise apparently must cause the audible noise I was hearing.
Set my radio to 500hz and not a sound!
[-] The following 1 user Likes skamtastik's post:
  • hugnosed_bat
  Help over 40% throttle motor1 spin up endless ap79 8 165 6 hours ago
Last Post: ap79
Sad Help EMAX ECOII 2807 130kkv 7" noise steamfpv 2 49 10 hours ago
  Help 35mm Bi-Blade Prop 1mm Shaft brettbrandon 8 120 10-May-2024, 08:21 AM
  Help Mobula 8 after crash motor ramp up to max with minimum throttle johnny1234 7 1,074 31-Mar-2024, 05:43 AM
Last Post: spiralthomas
  New motor making clicking noise bortek 2 305 14-Oct-2023, 06:04 PM
Last Post: Rob3ddd
