Threads: 75
Likes Given: 3,949
121 I mean, it certainly doesn’t sound healthy, but I don’t have a mic on any of my builds so I can’t say if it’s abnormal.
If your prop tips flex up or down, is there anything they can hit?
If I recall correctly, you used new motors on this build, so it’s unlikely your bearings are worn out.
I suppose it could be an esc setting, but it certainly sounds mechanical to me. If you grab your bells, can they lift off of the stator at all?
Dangerous operations.
Threads: 75
Likes Given: 3,949
121 18-Jul-2023, 12:47 AM (This post was last modified: 18-Jul-2023, 12:49 AM by Lemonyleprosy.) Nope, I can’t explain.
The “I suppose” was because it sounds plausible to me that an esc setting could cause it, but I don’t have the knowledge to be able to say whether it is or isn’t, or what setting may change it.
In my head, it makes sense that it could potentially be active braking, so I might consider reducing braking strength and see if it makes a difference- but that is a wild guess based on speculation and lack of knowledge, NOT a recommendation.
I still think it sounds mechanical. Something rubbing/hitting/vibrating.
Sorry that’s not super helpful.
I’m inside so I can’t listen to your video again without upsetting my critters- does it happen when throttle is cut regardless of angle of attack? In other words, if you go straight up, then cut the throttle, does it happen? Or does it primarily happen as you cut throttle and pitch back to reduce forward movement?
Threads: 9
Likes Received: 40 in 31 posts
Likes Given: 96
3 I dont really have enough video footage to gather the exact data. But it seems like it's when I throttle hard up, then immediately bring it back down to 0 I create the issue. But like if I throttle up and ease off the stick and slowly bring to 0 then it's not happening.
Hoping tomorrow plays nice with weather and all I'll do is take video to collect data and see if I can narrow that down. But I also want to see what happens with the GoPro off and see if I can hear it above me.
Threads: 9
Likes Given: 96
3 I FIGURED IT OUT!!!
When I built the quad, I used the SupaFly preset tune in Betaflight. When selecting this preset, there's an option to select a receiver and I selected ELRS. Wellllllll, it clearly states that its ELRS at 500hz, however my Boxer is set to 1000hz. This excess non-audible-noise apparently must cause the audible noise I was hearing.
Set my radio to 500hz and not a sound!
