24-Feb-2024, 07:21 PM
I am using a FlySky (which is NOT the same as FrSky) i10 Transmitter and iA6C receiver. The receiver has both SBUS and PPM output.
After trying unsuccessfully for days to get the SBUS working, I decided that I needed to go back to PPM. I connected the PPM output of my
receiver to the "R" pad on my SpeedyBee f405V4 board. I had it previously connected to the SBUS pad.
In the PORTS screen I turned the "SERIAL Rx" slider OFF. Then I SAVED and rebooted.
In the RECEIVER tab, it said "Serial (via UART)". I changed that to "PPM". I SAVED and rebooted.
When I connect again, it still says "Serial (via UART)" and refuses to change. No matter how many times I set it to PPM,
it will not change.
What am I doing wrong?
I realize that PPM isn't as responsive as serial, but I couldn't get any serial mode to work. I just want to get this thing in the air.
it will not change.
