22-Apr-2022, 02:09 PM
Hi everyone,
I am building a quadcopter (first one I am building on my own, second one I own in total) and more or less it is already working, it flies I have video etc., but the quad ... twitches every now an then which feels very bad.
Video of the issue: https://drive.google.com/file/d/1M0R9QrW...sp=sharing
The FC I am using is a flywoo GOKU HDF4 EVO + dji air unit + 1106 motors. The fc uses blheli s but I flashed a dshot enabled firmware. The frame is from a transtec beetle which I was gifted by a friend (also the reason I got those motors).
I believe I have already identified the issue to a certain degree.
As far as I can tell the FC needs softserial to transmit the osd to the googles (because the setup sheet says softserial tx B04 / rx B00) and I guess softserial sometimes takes too long and stalls the entire fc and then it overcompensates which causes the twitching.
Because if I disable soft serial and not go without the osd the twitching is gone.
I already lowered pid loop from 4k to 2k but it didn't change anything concerning the twitching.
However without the OSD I can not tell how much battery I have used and that seems fatal to me as well.
So my question is can I
a) somehow get rid of this twitching by changing some settings in BF for the osd or the soft serial output or
b) can I somehow not use softserial with this fc, because my other drone does not need it or
c) can I somehow output battery voltage any other way to the goggles?
thanks for your help
