Threads: 18
Likes Received: 1 in 1 posts
0 To whom it may concern, I appreciate this platform exist. I recently upgraded my built quad and adding a gps on it. In the process of programming and activating the GPS in betaflight I started running issues with betaflight not able to connect to the drone I get the error message all the time. I have uninstall and reinstalled and it now not working probably. I updated the drivers with cp210x driver, stm usb vocal driver, tried the dc impulse driver and tried zadig and I’m not sure what do from here on? I would appreciate your assistance thank you
Threads: 583
Likes Received: 8,942 in 6,617 posts
Likes Given: 1,425
786 Are you able to put your FC into boot mode (by holding the boot button down while plugging in a USB cable) and does Betaflight Configurator then recognise it as a "DFU" connected device?
Threads: 31
Likes Received: 208 in 158 posts
Likes Given: 95
14 If that really happenned as soon as you added the GPS and you have an older board like a F3 I would guess that you used the same TX/RX that is allocated to the cp210 board where you plug in your usb.
Like Snow said, try to connect to it via DFU. If you are able to do that then you can reflash your firmware into the board and start over.
Threads: 18
0 When held down the reboot button and plugged in it the betaflight configurator didn’t recognize it. I deleted the betaflight and reinstalled it and it did not work.
Threads: 38
Likes Given: 430
118 What FC do you have? How did you wire the GPS?
Try unplugging the GPS and then connecting the board to Betaflight. Does this work?
Threads: 18
0 Mamba F405 MK2, i looked it up online, I used the uart3. I tried unplugging it and to see if It would make a difference it is still not connecting
Threads: 18
0 Yes the flight controller powers up and it still works. You might right about the USB port might be bad. I tried my tinyhawk on the computer and it wouldn’t connect either
I’m sure of what to do, I might have to buy another computer
Threads: 18
0 So tried different usb B cord none of them made difference. I ordered the OTG cable from Amazon so I would try using my iPhone, I have an old android phone that I tried to login and I was unsuccessful so I would try using my iPhone hopefully it would work. Thank you guys I would let you know the outcome in the next couple of days
Threads: 125
Likes Given: 99
388 Go to device manager, plug in your FC with USB cable, what device populates in the device manager?
Threads: 49
Likes Received: 192 in 157 posts
Likes Given: 186
11 22-Jun-2021, 04:59 AM (This post was last modified: 22-Jun-2021, 05:01 AM by Kevin2112.) Have you tried using every different USB port on the computer? I did something to a couple of my ports when I started adding the various drivers you tube videos said you needed and instead it screwed em up.
There are usually a couple USB ports on the interior on the mother board (desk top) that might have survived and not been corrupted.
Threads: 18
0 I did tried other ports and it was still giving me the same error message. I had an old hp i3 laptop that I was going to use but I can’t find so I am hoping I can use my phone with betaflight
