Possible bug with Betaflight Pre-arm
Currently I can not test this any further on another build until replacement parts arrive for my quads in the next few days. But I wanted to know if anyone else has experienced this.
QuadStyles brought this to my attention after one of his last flying sessions where i just enabled a pre-arm switch on his FS-i6. His battery was ejected in a crash. Quad and battery are fine. He had forgot to deactivate the pre-arm switch and after plugging the lipo back in, forgetting about the pre-arm switch he was able to fully arm the quad again with only the main arming switch.
So order of events to repeat event.
1. Plug in, pre-arm, arm = motors idle
2. Disarm (main arming switch only) and unplug lipo
3. Plug lipo back in, wait for beeps, leaving pre-arm still activated, (no warnings or reset for flysky fs-i6 to remind him)
4. Arm switch now works without pre-arm!
FC is a JB F4 AIO with Flysky X6B Rx running iBus. I will be able to see if it's the same with my Frsky when parts get here. But I don't know if it is a betaflight bug or in the FC maybe.
My hunch is in BF.
The Obsession IS Real!
I can test this as soon as I get a chance. All of my quads have pre-arm enabled and I use Frsky. I've never noticed this behavior before but I don't know if I've ever done that sequence.
I'd rather be flying!
My Builds
YouTube
Could always switch one of the fsi6 switches out with a momentary switch that way it’s only every pre armed when you physically pop that switch
(27-Jun-2018, 05:37 PM)Jakefpv Wrote: Could always switch one of the fsi6 switches out with a momentary switch that way it’s only every pre armed when you physically pop that switch
That would be a way to not have to worry about it Smile
  • Jakefpv
(28-Jun-2018, 01:30 AM)Drone0fPrey Wrote: That would be a way to not have to worry about it Smile
Might end up being more effort than it’s worth, however saw a video with a guy doing similar on an fsi6.
With the firmware upgrade you could have much more potential.
(29-Jun-2018, 02:59 PM)Jakefpv Wrote: Might end up being more effort than it’s worth, however saw a video with a guy doing similar on an fsi6.
Wink
http://intofpv.com/t-easy-flysky-fs-i6-1...el-upgrade
I forgot to test this on my Frsky yesterday. Will try to remember if I can get out today. Doh
(29-Jun-2018, 03:35 PM)Drone0fPrey Wrote: Wink
It works just fine!
(29-Jun-2018, 03:53 PM)Jakefpv Wrote: It works just fine!
Following the same procedure as in OP?
  • Jakefpv
(29-Jun-2018, 05:21 PM)Drone0fPrey Wrote: Following the same procedure as in OP?
Fsi6 with flit10 so different rx, shouldn’t matter though.
When I went to plug lipo in with pre arm it wouldn’t arm without first flipping pre arm back.
I’m on newest betaflight on fc and newest stable betaflight configuration on PC.
Tested 3 times wouldn’t let me arm any of the three times.
Either a bug in betaflight but needs to be specifically set up, an older version of bf and an issue that’s since been removed, or an issue with the rx possibly?
Tried on my mantis 85
Did you first arm then disarm leaving pre arm still on.
THEN unplug and plug back in
Ok I just confirmed using my Frsky. Does this on the JB F4 and HGLRC F4.
I am running BF 3.3 on all our FCs and use BF Config 10.2
I had forgotten to try, too. I just tried one with a Lumenier AIO FC and it worked fine and didn't exhibit this problem. I'll try today on my OBF4 and Hobbywing FC. I plugged in, pre-armed then armed. Then I disarmed, unplugged and replugged leaving the pre-arm switch on. It would not arm until I reset the prearm switch.
My Builds
YouTube
[-] The following 1 user Likes Hypurr's post:
  • Drone0fPrey
(30-Jun-2018, 02:20 PM)Hypurr Wrote: I had forgotten to try, too. I just tried one with a Lumenier AIO FC and it worked fine and didn't exhibit this problem. I'll try today on my OBF4 and Hobbywing FC. I plugged in, pre-armed then armed. Then I disarmed, unplugged and replugged leaving the pre-arm switch on. It would not arm until I reset the prearm switch.
Nice. That's good.
What BF version are you running?
  [SOLVED] betaflight 4.4 rx configuration for frsky r-xsr sim_tcr 7 2,391 18-May-2024, 07:25 PM
  Announcement Betaflight 4.5.0 *** FINAL RELEASE *** Now Available SnowLeopardFPV 4 887 08-May-2024, 02:19 PM
Exclamation Betaflight Configurator - HELP iFly4rotors 11 645 05-May-2024, 08:09 PM
Last Post: Eyes.fpv
  Announcement Betaflight 4.5.0 Release Candidate 4 Now Available SnowLeopardFPV 8 2,680 15-Apr-2024, 06:50 PM
  Betaflight Configurator Windows - Bluetooth Connection norseman73 1 277 17-Mar-2024, 02:55 PM
