09-Oct-2020, 12:03 AM (This post was last modified: 09-Oct-2020, 12:20 AM by OneEyedFPV.)
If I pulled the motor 4 esc sensor pad off a pdb, https://www.getfpv.com/lumenier-mini-4po...l?___SID=U, what can I do? Did look for a jumper but don’t want to solder to a capacitor.
As I am using BLheli S
Escs, what if I doubled the m4 esc sensor wire to another esc sensor pad, wouldn’t I get the accurate current draw in the OSD even though they wouldn’t be accurate individually in Betaflight?
Or what if I switched all esc sensor wires to the telemetry pads, used the telemetry slot on the pigtail and kept the wire to current sensor on the fc?
