29-Apr-2023, 07:08 PM (This post was last modified: 01-May-2023, 03:39 PM by truglodite.)
I'm setting up a quad with a Holybro Kakute H7 v2, and a Holybro Tekko32 65 metal 4in1, 4.4.1, and can't for the life of me get the current sensing to work properly. I did a test flight and throttle pumps with biblades got pegged at 182A (46 per motor). Put tri blades on and got the same result. This is on a setup that should draw like 60A (avenger 2808-1500, 6s, hq 7040 triblade). This is using the FC adc, with the amp scaling set to 180 per holybro website for my esc that is marked "v1.7":
https://docs.holybro.com/esc/current-sensor-scale
I tried as well using esc telemetry, but that doesn't seem to work at all (zero current). I think there's a new bug with esc telemetry in betaflight due to tx/rx switching. However I also haven't read across anyone ever getting the 65 metal esc current telemetry working anywhere.
I figure I may be doing something wrong... but the math seem to line up with 3.3V limit on the adc (18mV/A at 182A). If it scaled to 5.0V then yeah, 65A would be in range. Can someone please shed some light and help straighten my brain out on this one? Anyone else deal with this problem on their setup? Anyone have an h7+metal stack with current functioning properly? Anyone have esc telemetry working on their Kakute h7 with 4.4.1?
Thanks in advance,
Kev
Thanks in advance,
Kev
