15-May-2023, 01:18 AM
So i flew my new 7'' over the weekend for the first time in an area where i could push range/flight time, and nearly lost it due to the amps/MAH reading being so far off.
I fly a 1500 6s, and the OSD told me i had used ~700mah, so i figured i was fine. Im just upgrading from 4s so im not used to the way 6s lipos sag less at the end of the pack, so i didnt notice an issue until i was going down. in hindsight, i should have realized that my heavy 7'' quad carrying a gopro probably isnt drawing only 12 amps at like 70kph either.
I used Oscar Liangs post, here , to attempt to adjust the scale to a better range, and tested the past few days. Using his equation, i went from the 490 scale given by speedybee (the 50a blheli32 one thats in the f7 stack), down to 366. His equation for anyone who doesnt want to click over there is new_scale = old_scale x (OSD_mAh_consumed / mAh_charged) .
I had drawn 543mah and my charger listed 726mah going back in, multiplied by 490 to get 366.
Today, i flew for 698mah drawn, but still put in 960, which apparently should be a 266 scale. Does this seem wrong to anyone else, that speedybees stock scale could be off so far, and that it would need two corrections that large back to back?
I'm going to pick up some alligator clips in order to test with a multimeter tomorrow, as i don't trust this method anymore. In the meantime, does anyone see something im doing obviously wrong? Thanks in advance for the help
