Threads: 10
Likes Received: 20 in 12 posts
Likes Given: 14
3 I've got DYS Bl20 ESCs paired with Multistar V-Spec 2205 2300kv. With KingKong 5040 (two blades) all motors pull ~60amps on the ground (measured with a clampmeter), now I've ordered KingKong 5040x3 and I'm wondering if the ESCs can take it. Thanks!
Build - Fly - Crash - Repeat
Threads: 66
Likes Received: 350 in 248 posts
Likes Given: 164
34 30-Sep-2016, 10:35 AM (This post was last modified: 30-Sep-2016, 10:35 AM by oyvinla.) Full throttle while holding the quad down? If so, this will be static thrust and it will not draw that much while in the air. I fly with kingkong 5045 3 blade on 20 amp escs without any problems. The max current I get whit those in the air is about 70 amps, and those props are heavier than the 5040 tris
Threads: 10
Likes Given: 14
3 (30-Sep-2016, 10:35 AM)oyvinla Wrote: Full throttle while holding the quad down?
Yes.
Thank you very much
Threads: 56
Likes Received: 335 in 196 posts
Likes Given: 183
15 i fly daily on 20 A esc, and use 5045 HBN from DAL... no burners yet
All the best
Grzesiek (Grisha/ Greg)
Curently flyable: Nox 5, Minimalist 112
Bench / in progres: fixing Nox 3, Scrap
thinking about building: 450
Threads: 56
Likes Given: 183
15 03-Oct-2016, 08:36 PM (This post was last modified: 03-Oct-2016, 08:36 PM by Grisha0.) yup cobras... forgot to add, those are triblades... so not that easy to kill the hardware
All the best
