Threads: 1
Likes Received: 0 in 0 posts
0 Noxe f4 flight controller. It will not read voltage on the osd or in betaflight and I have many of these with the same problem.Running latest Betaflight and hrc 15amp 4×1 esc unable to get voltage read on osd or even in Betaflight.Running latest betaflight firmware. Everything works rssi altitude but no voltage.
Threads: 1
0 I found the problem.In the voltage section it needs to be in the onboard adc and also in config usb needs to be checked and then it will read voltage. Must be some loop problem as to why usb needs to be checked in the beeper section.
Threads: 125
Likes Given: 99
388 Weird, the beeper section should have nothing to do with the voltage.
