04-Jan-2018, 06:11 PM (This post was last modified: 04-Jan-2018, 06:12 PM by braden_smoker.)
Need help finishing first build |
04-Jan-2018, 08:32 PM (This post was last modified: 04-Jan-2018, 08:32 PM by raspberrypi33.) Sorry, I haven't used KISS firmware before. Only Betaflight. There are probably a lot of differences in them, but if the problem persists, you could switch FCs as a last resort. Maybe even get a new receiver? If it ain't broke, DON'T FIX IT! My YouTube FPV Channel 04-Jan-2018, 09:42 PM Everything looks like it is setup correctly. I don't use Kiss, so I don't know how to use a different UART to connect your RX. 06-Jan-2018, 01:50 PM (03-Jan-2018, 11:28 PM)braden_smoker Wrote: Why are there no antennas connected to your receiver? As the X4R is a telemetry receiver, it will be trying to transmit telemetry back to the radio. Without any antennas connected, this will destroy the output stages on the RF transceiver chip, and maybe the inputs as collateral damage. 07-Jan-2018, 03:55 AM (06-Jan-2018, 01:50 PM)unseen Wrote: Why are there no antennas connected to your receiver? I took them off for the picture. 07-Jan-2018, 01:21 PM (07-Jan-2018, 03:55 AM)braden_smoker Wrote: I took them off for the picture. I'd put the antennas on and leave them on if I were you. The u.fl connector is not designed for more than 30 connections/disconnections. If you're not very careful to ensure that the parts are completely parallel with each other when pressing the connectors together, you'll get far less than 30 connections/disconnections before the antenna side of the connector stops making a good connection. |
Build Rekon5 UL 5" build | ph2t | 51 | 8,031 | 12-Apr-2024, 02:26 AM Last Post: ph2t | |
Build Micro Apex 4" Build | drumgod | 8 | 409 | 11-Apr-2024, 12:05 AM Last Post: BigBeard | |
Build Helios - 3.5” Sub-250g (Sub 160g possible) DJI O3 Drone – Frame/Build Thread | Recursion | 12 | 1,872 | 25-Mar-2024, 10:28 PM Last Post: Recursion | |
Build 5in lightweight build | hawk01 | 37 | 1,391 | 22-Mar-2024, 10:56 AM Last Post: Jossey | |
Build Whoosh - 3.5" build. PID settings? | maxer | 23 | 1,188 | 30-Dec-2023, 08:29 PM Last Post: SnowLeopardFPV |
