My second build
(16-Jul-2020, 11:56 AM)SnowLeopardFPV Wrote: No problem Smile
One thing to be careful of that I forgot to mention. The Kakute F7 FC has metal rings around the mounting holes. Use a multimeter to check that those aren't connected to anything on the board, and if they are then that they're only connected to the ground plane on the FC and not something else. If they are connected to something other than the ground plane then you are going to need to insulate the holes from the metal screws in some way. Hopefully they are just reinforcement rings and nothing more. Unfortunately I don't have one of the same FC's so I can't check for you.
Rings on the mount holes are connected to each other and to every ground pad. I will use plastic standoffs so that is not a problem I guess...
btw I decided for TBS unify pro32 VTX and Foxxer predator v4 mini/standard version... i will place order for them soon so I can start building Smile
I didn't see you around over the last week or so, so if you missed the following thread then I suggest you have a read of it so you are aware, because the issue may also affect you...
https://intofpv.com/t-warning-holybro-te...ware-issue
:O god damn, so I'm safe if I'm using 4S setup?
#19
(10-Aug-2020, 02:07 PM)ssaakkaa Wrote: :O god damn, so I'm safe if I'm using 4S setup?
No guarantees, but probably. Set PWM frequency to 48KHz and don't switch on bi-directional DSHOT. Then thoroughly test over an empty field where you can easily retrieve the quad if it flips out and crashes.
#20
damn xD when you paying for the best but it's not really :'(
#21
Yes, I'm not particularly impressed either after having spent so much money on what I considered to be one of the best 4in1 ESCs out there. And I'm going to be running mine on 6S too, so that means even more of a risk. It almost makes me wish that I'd got one of the cheaper Mamba F60 Pro ESCs instead that doesn't make use of an F3 MCU.
I just hope the BLHeli32 developers can come up with a workable solution.
#22
I hope so :S thank you for info Smile
#23
FYI, it looks like we might possibly be OK with the latest version of the Metal ESC we both have. See the following post and anything below it...
https://github.com/bitdump/BLHeli/issues...-672737092
  • ssaakkaa
#24
Thank you Smile Snow you are awesome Smile
#25
You probably already found the response to me from ChrisRosser (HERE), but it looks like we should be OK as long as we install the 32.7.2 test version of the BLHeli32 firmware. Chris has confirmed that seems to fix all the issues on the Holybro ESC boards which have the separate daughterboard containing the control circuit like on the board we both have. I will obviously still be doing my maiden flights over an empty field to start with (once it's built) until I build up some confidence that there are definitely no remaining issues.
  • ssaakkaa
#26
I'm waiting for some parts so waiting for two or three weeks is inevitable for me Smile
#27
While you are waiting for your parts, the following video by Drone Mesh which was published earlier today should make you feel a bit better about having spent $75 on an ESC Smile
#28
that's what I hoped for when i was buying that ESC Big Grin how is your new build progressing? when is the maiden flight?
#29
(14-Aug-2020, 08:55 AM)ssaakkaa Wrote: how is your new build progressing? when is the maiden flight?
Banggood are messing me around with one of my orders so I have no idea when it will even be dispatched. Every day I check the status it says expected shipping in 2 days time. Then the next day the expected shipping date has moved on by another day, so for the last month the expected shipping date has always been today + 2 days Rolleyes And when it does eventually ship (if it ever does) I will have another 2-3 weeks wait while it is in transit. At this rate, flying season will be over this year before I even manage to complete the build.
  • ssaakkaa
#30
auch xD the same thing was happened to me with some motors, so I got the motors 8 months later :') In the situations like that I was contacting the support every day until they resolve my problem XD so good luck with that XD
  Build Helios - 3.5” Sub-250g (Sub 160g possible) DJI O3 Drone – Frame/Build Thread Recursion 13 2,106 14-May-2024, 09:55 AM
Last Post: FloppyFish
  Build Micro Apex 4" Build drumgod 18 974 09-May-2024, 01:33 PM
Last Post: drumgod
  Build Rekon5 UL 5" build ph2t 51 8,261 12-Apr-2024, 02:26 AM
Last Post: ph2t
  Build 5in lightweight build hawk01 37 1,470 22-Mar-2024, 10:56 AM
Last Post: Jossey
  Build Whoosh - 3.5" build. PID settings? maxer 23 1,248 30-Dec-2023, 08:29 PM
