Motors vibration and stutter
Goodmorning ,
I have a problem with motors that take vibration and stutter.
The motors are very hot After few seconds
Now the drone generates a sound very strong at full Trottle and doesn’t take off
I don’t understand…
Quote:Luca_sho_
motors/props rotating correctly? Props on the right way up?
Yes, the work correctly, i’ll try again anyway and check.
Quote:Luca_sho_
Goodmorning,
i'd like to share the video in which the motors stutter and vibrate. The motors are new. Can someone help me with this problem? Thank you.
https://youtube.com/shorts/cFIWapIYs2A
Quote:Luca_sho_
Swap over a good motor with the bad motor to see if its actually the motor or the ESC.
Sounds bad.
Maybe bad bearing.
But if you actually see the propeller stuttering and like not turning smoothly. I had that issue with a "half" burned FET. Motors were super hot after 20 sec of hovering.
Problem solved by replacing the motor
Quote:Luca_sho_
  Can $5 motors be any good? 1805-1550kv mstc 3 71 Yesterday, 03:04 AM
  Motors spin rough then stop MajorKook 4 69 18-May-2024, 08:53 PM
Last Post: MajorKook
  one of the motors does not arm balabushka 4 138 01-Apr-2024, 09:54 PM
  Skystars 1404 motors (any kv) Pathfinder075 16 761 14-Mar-2024, 10:56 PM
  Solved 2004 3000kv motors on 6s Mad35 6 273 12-Mar-2024, 06:05 AM
Last Post: Mad35
