Threads: 13
Likes Received: 2 in 1 posts
Likes Given: 7
0 Goodmorning ,
I have a problem with motors that take vibration and stutter.
The motors are very hot After few seconds
Now the drone generates a sound very strong at full Trottle and doesn’t take off
I don’t understand…
Threads: 71
Likes Received: 339 in 253 posts
Likes Given: 156
19 motors/props rotating correctly? Props on the right way up?
Threads: 13
Likes Given: 7
0 Yes, the work correctly, i’ll try again anyway and check.
Threads: 38
Likes Given: 430
118 Swap over a good motor with the bad motor to see if its actually the motor or the ESC.
Threads: 92
Likes Given: 0
27 Sounds bad.
Maybe bad bearing.
But if you actually see the propeller stuttering and like not turning smoothly. I had that issue with a "half" burned FET. Motors were super hot after 20 sec of hovering.
Threads: 13
Likes Given: 7
0 Problem solved by replacing the motor
