Threads: 10
Likes Received: 2 in 2 posts
0 Hey everyone, I am trying to wire up 2 Hobbywing 60a 4in1 ESCs to a Matek F722-HD, I wanted to ask, there's two ESC connectors on the FC which I have wired correctly and all, but I am not sure, both of them have a VBAT pin, and was wondering if I plug both connectors with VBAT into the FC wouldn't it be too much or something? Or would it use just one of the VBAT pins. Thanks alot.
Threads: 4
Likes Received: 62 in 57 posts
Likes Given: 17
8 03-Dec-2022, 05:47 PM (This post was last modified: 03-Dec-2022, 05:50 PM by matt0725.) You can use one or both, it makes no difference, assuming both ESC's are running off of the same battery pack. all of it is in parallel, so you wouldn't be giving it double the voltage or anything like that.
edit: if you are using 2 separate packs, just leave one vbat wire out.
