Threads: 17
Likes Received: 58 in 41 posts
Likes Given: 20
2 I had a minor crash in dirt (hard dirt) and I think the onboard analog to digital convert got whacked. The voltage bounces around all over the place in betaflight.
Is there an external sensor I can use that would be cheaper than buying a whole new AIO?
Threads: 118
Likes Received: 1,411 in 728 posts
Likes Given: 1,069
41 I've read where the issue of OSD readings for voltage vary all over the place to place a small capacitor across the pins that take power and ground for the ADC IC. This is for FCs from the factory that havent taken a crash so may not work. What version of the aio fc do you have? Have you been able to identify the ADC IC on the board?
Threads: 17
Likes Given: 20
2 30-Nov-2022, 04:10 AM (This post was last modified: 30-Nov-2022, 06:56 AM by Fiveflat.) Flashing Bluejay didn't have any effect on this ADC after all.
Does anyone know if the current sensor is legitimate or is current just a calculation? The betaflight tab leaves me to believe it's just a calculation. If it's not then it seems like that actually works as it should.
That's good news as I rely more on that than the voltage sensor anyway...
Threads: 17
Likes Given: 20
2 That m30 likely seems to be my issue. Current sensing appears to work, but voltage sensing took a huge crap.
Threads: 17
Likes Given: 20
2 I reached out to Diatone and they responded, telling me the Voltage sensor is on the FC while the current sensor is on the ESC. Does that make sense being an AIO? I understand they are two different entities on an AIO...
Threads: 38
Likes Given: 430
118 For an AIO it makes no sense to me.
The shunt resistor aka current sensor even on a ESC (part of a stack) simply passes the analog current data to the FC via the Curr wire and we set it up as an ADC current meter in Betaflight.
Back in the day with Omnibus F4 FC’s we had a current sensor on the FC and again it was setup as an ADC current sensor.
