Low throttle PID
Guys everytime I drop my throttle my PIDS go all crazy.  I'm getting a pretty constant wobble as well.  I know a lot more info is needed but off the cuff what do you all think?
[Image: fsa1W]
http://imgur.com/a/fsa1W
Quads:  RealACC X6R ; RealACC X210 Pro, Omnifbus F3 FCs; RunCam Swift 2 & Swift 2 Rotor Riot, Emax OG Red Bottoms, Emax RS2205S 2300kv; Fatshark DOM V3 YouTube - Mr.E_fPv
maybe you can just post your blackbox log? can't tell much just from that screenshot
  • rryyyaann
What could cause the PIDS to be dropping out every time the throttle is low.  As long as i stay on the throttle its pretty locked in.  I am in Airmode too.  I don't have any blackbox from my latest tune it helps to have the SD card installed in the FC, duh.
UPDATE: Here's the most recent Black Box
Black Box
THANKS
I really don't understand how you have this craft tuned....
These PID values seem to be ridiculously high.
[Image: 4bRoONWl.png]
I'm not sure what you mean by "PIDs dropping out".
LOL... yea those PID values are a bit extreme... Big Grin
I will take a look at the BB log when I get home
I wouldn't fly until you get some input from Oscar. Those D settings on pitch and roll are quite high, I'm guessing your motors are getting pretty hot?
PID are way way way too high !
Try this values instead for the start
Roll P 55 I 45 D 20
Pitch P 65 I 55 D 25
Yaw P 90
report back if you can Smile Play with Set Point weight (0.7-1.0) before further changing D Smile
Your quad is pretty clean of noise, so it should fly relatively nice Smile and you are lucky you haven't burned your motors yet LOL
  • unseen, rryyyaann
(13-Jun-2017, 12:11 AM)Oscar Wrote: PID are way way way too high !
Roll P 55 I 45 D 20
Yaw P 90
Thanks for the info!
I'll give these values a try and adjust the set point weight of D.
Trust me I understand what you're saying.  I have had very similar PIDS to what you have suggested and the thing flies like garbage.  My motors aren't even getting a little warm which also surprised me.  So I just kept cranking things up and up.  I dont get it.  It's probably just time to get new motors.  The esc maybe have 10 flights on them. The board was just installed Saturday.  Everything sounds smooth but who knows.
Its a ZMR250
Emax 2204 2300kv motors
Little Bee 20a opto ESC
Omnibus F3 FC
HQ 5x4x3
(12-Jun-2017, 10:47 AM)unseen Wrote: I really don't understand how you have this craft tuned....
Dropping out isn't the right way to say it.  When I let off the throttle control sloppy and the quad bumps around like the PIDS arent doing anything.  Get back on the throttle things are better.  This is not my only quad.  MY x210 is tuned pretty solid and flies great.
you are using 4S right?
(13-Jun-2017, 01:04 AM)Oscar Wrote: you are using 4S right?
Yeah 1300 4S
What is your min_throttle set to? Could it be too low and allowing the props to slow too much?
The Obsession IS Real!
(13-Jun-2017, 07:31 AM)Drone0fPrey Wrote: What is your min_throttle set to? Could it be too low and allowing the props to slow too much?
DOP that's a good thought just checked it an Min is at 1065
I'm going to try Oscar's suggested PIDS this morning and report back with the blackbox.  Thanks for all the help!
UPDATE:  Here is the latest blackbox using Oscar's suggested PIDS.  I dont know what the heck is happening.  BlackBox
CLI
# dump
# Betaflight / OMNIBUS 3.1.7 Apr  3 2017 / 22:14:20 (e1c4b5c)
name Mr.E_Fpv
resource BEEPER 1 C15
resource MOTOR 1 B08
resource MOTOR 2 B09
resource MOTOR 3 A03
resource MOTOR 4 A02
resource MOTOR 5 B07
resource MOTOR 6 B06
resource MOTOR 7 NONE
resource MOTOR 8 NONE
resource MOTOR 9 NONE
resource MOTOR 10 NONE
resource MOTOR 11 NONE
resource MOTOR 12 NONE
resource SERVO 1 NONE
resource SERVO 2 NONE
resource SERVO 3 NONE
resource SERVO 4 NONE
resource SERVO 5 NONE
resource SERVO 6 NONE
resource SERVO 7 NONE
resource SERVO 8 NONE
resource PPM 1 B04
resource PWM 1 NONE
resource PWM 2 NONE
resource PWM 3 NONE
resource PWM 4 NONE
resource PWM 5 NONE
resource PWM 6 NONE
resource PWM 7 NONE
resource PWM 8 NONE
resource LED_STRIP 1 A08
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 A14
resource SERIAL_TX 3 B10
resource SERIAL_TX 4 NONE
resource SERIAL_TX 5 NONE
resource SERIAL_TX 6 NONE
resource SERIAL_TX 7 NONE
resource SERIAL_TX 8 NONE
resource SERIAL_TX 9 NONE
resource SERIAL_TX 10 NONE
resource SERIAL_TX 11 NONE
resource SERIAL_TX 12 NONE
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 A15
resource SERIAL_RX 3 B11
resource SERIAL_RX 4 NONE
resource SERIAL_RX 5 NONE
resource SERIAL_RX 6 NONE
resource SERIAL_RX 7 NONE
resource SERIAL_RX 8 NONE
resource SERIAL_RX 9 NONE
resource SERIAL_RX 10 NONE
resource SERIAL_RX 11 NONE
resource SERIAL_RX 12 NONE
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -CURRENT_METER
feature -OSD
feature -BLACKBOX
feature -TRANSPONDER
feature -AIRMODE
feature -SDCARD
feature -VTX
feature -RX_SPI
feature -SOFTSPI
feature -ESC_SENSOR
feature -FEATURE_ANTI_GRAVITY
feature VBAT
feature RX_SERIAL
feature FAILSAFE
feature CURRENT_METER
feature OSD
feature BLACKBOX
feature SDCARD
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
map TAER1234
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 0 0 0 1700 2100
aux 1 28 1 900 1300
aux 2 4 3 1300 1700
aux 3 27 2 900 1300
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
adjrange 12 0 0 900 900 0 0
adjrange 13 0 0 900 900 0 0
adjrange 14 0 0 900 900 0 0
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
rxfail 3 a
rxfail 5 h
set task_statistics = ON
set min_check = 1100
set max_check = 1900
set rssi_channel = 9
set rssi_scale = 30
set rc_interp = AUTO
set rc_interp_ch = RP
set rc_interp_int = 19
set rssi_invert = OFF
set fpv_mix_degrees = 0
set max_aux_channels = 14
set debug_mode = NONE
set min_throttle = 1020
set max_throttle = 2000
set digital_idle_percent =  4.500
set use_unsynced_pwm = OFF
set motor_pwm_protocol = ONESHOT125
set motor_pwm_rate = 480
set disarm_kill_switch = ON
set small_angle = 25
set fixedwing_althold_dir = 1
set beeper_inversion = ON
set beeper_od = OFF
set serialrx_provider = SPEK2048
set sbus_inversion = ON
set spektrum_sat_bind = 0
set spektrum_sat_bind_autorst = 1
set tlm_switch = OFF
set tlm_inversion = ON
set sport_halfduplex = ON
set frsky_default_lat =  0.000
set frsky_default_long =  0.000
set frsky_gps_format = 0
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set hott_alarm_int = 5
set pid_in_tlm = OFF
set bat_capacity = 0
set vbat_scale = 113
set vbat_hysteresis = 1
set ibat_scale = 252
set ibat_offset = 56
set mwii_ibat_output = OFF
set current_meter_type = VIRTUAL
set battery_meter_type = ADC
set bat_detect_thresh = 55
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_yaw = -180
set gyro_lpf = OFF
set gyro_sync_denom = 1
set gyro_isr_update = OFF
set gyro_use_32khz = OFF
set gyro_lowpass_type = PT1
set gyro_lowpass = 90
set gyro_notch1_hz = 0
set gyro_notch1_cut = 300
set gyro_notch2_hz = 0
set gyro_notch2_cut = 100
set moron_threshold = 48
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 1
set yaw_deadband = 3
set thr_corr_value = 0
set thr_corr_angle = 800
set yaw_control_direction = 1
set yaw_motor_direction = 1
set servo_center_pulse = 1500
set tri_unarmed_servo = ON
set servo_lowpass_hz = 400
set servo_lowpass = OFF
set servo_pwm_rate = 50
set gimbal_mode = NORMAL
set failsafe_delay = 17
set failsafe_off_delay = 10
set failsafe_throttle = 180
set failsafe_procedure = DROP
set acc_hardware = AUTO
set acc_lpf_hz = 10
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = ON
set acc_trim_pitch = 0
set acc_trim_roll = 0
set baro_tab_size = 21
set baro_noise_lpf =  0.600
set baro_cf_vel =  0.985
set baro_cf_alt =  0.965
set baro_hardware = NONE
set mag_hardware = NONE
set mag_declination = 0
set pid_process_denom = 4
set blackbox_rate_num = 1
set blackbox_rate_denom = 1
set blackbox_device = SDCARD
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
set sdcard_dma = OFF
set osd_units = IMPERIAL
set osd_rssi_alarm = 20
set osd_cap_alarm = 2200
set osd_time_alarm = 10
set osd_alt_alarm = 100
set osd_vbat_pos = 2433
set osd_rssi_pos = 2074
set osd_flytimer_pos = 2454
set osd_ontimer_pos = 374
set osd_flymode_pos = 2062
set osd_throttle_pos = 2177
set osd_vtx_channel_pos = 200
set osd_crosshairs = 2048
set osd_horizon_pos = 200
set osd_current_pos = 2447
set osd_mah_drawn_pos = 2441
set osd_craft_name_pos = 2081
set osd_gps_speed_pos = 66
set osd_gps_sats_pos = 386
set osd_altitude_pos = 161
set osd_pid_roll_pos = 322
set osd_pid_pitch_pos = 354
set osd_pid_yaw_pos = 386
set osd_power_pos = 47
set osd_pidrate_profile_pos = 418
set osd_battery_warning_pos = 200
set vcd_video_system = 2
set vcd_h_offset = 0
set vcd_v_offset = 0
set pidsum_limit =  0.500
set pidsum_limit_yaw =  0.500
set d_lowpass_type = PT1
set d_lowpass = 111
set d_notch_hz = 260
set d_notch_cut = 160
set vbat_pid_gain = OFF
set pid_at_min_throttle = ON
set anti_gravity_thresh = 350
set anti_gravity_gain =  3.000
set setpoint_relax_ratio = 85
set d_setpoint_weight = 81
set yaw_accel_limit =  10.000
set accel_limit =  0.000
set iterm_windup = 50
set yaw_lowpass = 0
set p_pitch = 65
set i_pitch = 55
set d_pitch = 28
set p_roll = 55
set i_roll = 45
set d_roll = 20
set p_yaw = 90
set i_yaw = 40
set d_yaw = 55
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 50
set i_level = 50
set d_level = 100
set p_vel = 55
set i_vel = 55
set d_vel = 75
set level_sensitivity = 55
set level_limit = 55
set rc_rate = 103
set rc_rate_yaw = 103
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_srate = 75
set pitch_srate = 75
set yaw_srate = 75
set tpa_rate = 10
set tpa_breakpoint = 1650
UPDATE: I've confirmed through an unsafe method, that the number 3 motor is cutting out during flight. I'll pop some good motors on and see if that's the issue or the esc.
Guys I think it's a lost cause now. I reset EVERYTHING back to stock betaflight and now its tumbling out of the sky. It willl fly for a second then it just goes crazy. I'm thinking all this could be motor related. One motor sputters on start up and MIN throttle is 1070 its more than enough so I'm thinking that motor is cutting out mid air. I appreciate all your help but I dont think we need to waste our time anymore I'll get it figured out eventually.
Good news is its my old quad I was just trying to keep in the air.
I see min_throttle set @ 1020 in the dump you shared. But that does sound like a motor or ESC problem or even maybe ESCs need calibrating or solder joints checked.
Just some brainstorming Wink I hate it when a quad isn't flying Tongue Hope you get it figured out, who ever said an old quad can't learn new tricks Wink ROFL
  • Tom BD Bad
  PID Tuning Guide Oscar 5 27,166 03-May-2023, 12:06 AM
  Solved Quad gets shaky and loud over 30% throttle. Suros 10 454 23-Nov-2022, 10:37 PM
Last Post: Suros
  Throttle Range In Custom Setup DragonTheta 1 323 20-Apr-2022, 08:57 PM
Last Post: kafie1980
  Quad won't Arm Low Power Mode Unable to record videos Seanalami 3 560 27-Mar-2022, 11:13 PM
  Solved TS80 Soldering Iron - Low Voltage Warning / USB Issue SnowLeopardFPV 7 14,743 17-Oct-2019, 09:11 PM
