Losing control while rolling
Question
Hi guys, can you help me? Sometimes while doing a roll, I lose control of my quad, it just keeps spinning. It disarms mid-air. I don't know if it disarms itself or I do it because when I realize what is happening I immediately pull the disarm switch.
Too little informations friend. What's your build? Do you have a video?
You are absolutely right my friend! I have a GepRC zx5 and its PDB, xsr, SPRF3, Racerstar 30A ESCs Emax 2204 2300 KV, DAL 5045 triblade props, hs1177, tbs unify and a taranis.
4S 1300 75C Tattu battery
I am running Betaflight 3.0 with stock everything.
Unfortunately I have no video. It happens around halfway through the roll
Every single time?
Does it happen on flips too?
My initial thought would be a loose wire that only messes up when upside down. I had an issue where doing backflips caused my battery cable to come loose and restart the quad (didn't occur on rolls or front flips).
It happens in 1/3 of the rolls. I didn't try flips, I have just started doing tricks and I only do rolls right now. Thanks, I will see what happens
Sounds like what they refer to as death roll or yaw of death, common with BLHeli EScs desyncing. You can try setting your demag to high, but first just try upping your min throttle. That usually fixes it.
Alright, thanks, I will try that
I PM'd a buddy who knows a LOT more than me to make sure that I covered all the bases and he told me something else. Guys were having the same issue as you and what was happening was when they finished a build and motor nneded to be reversed, they were changing motor direction in BLHeli. When they set all the motors to normal direction in BLHeli then swapped wires on the ESCs, the problem was fixed. Don't know if this applies to you, but thought I'd just let you know.
Wow, that's weird. Thanks, will try
Try to do a Blackbox log. Then you will see what motor/esc is causing the problem it that is your problem.
I also don't think that the racerstar escs has the reverse motor desync problem like the dys escs if I remember correctly
I will try. What happens when the flash memory fills up? Does it start deleting the oldest data?
(25-Oct-2016, 03:28 PM)varkokonyi Wrote: I will try. What happens when the flash memory fills up? Does it start deleting the oldest data?
No, unfortunately it stops recording. But I assume you can have a quite low logging rate and still be able to see the problem if it is ESC desync/motor. You are looking for a motor that goes to full throttle when it happens.
Yup, I will set a low logging rate then. Thank you very much
dumb question from other angle... could it be possible that you are losing range on the rx and failsafe kicks in ?
All the best
Grzesiek (Grisha/ Greg)
thinking about building: 450
Nope, the quad was about 10 metres from me. Good idea though Smile
  Can a DJI RC Motion 2 control anything other than a DJI quad? Wellcordinated 8 623 17-Feb-2024, 05:00 PM
Last Post: segler999
  Drone looses control Swiftzn 6 333 23-Oct-2023, 09:51 AM
Last Post: Swiftzn
  Motors spin at Max speed after Arming no throttle control fredhead11 6 404 28-Sep-2023, 07:38 PM
Last Post: lyoha
  ESC losing config niuk 0 134 28-Sep-2023, 06:24 PM
Last Post: niuk
  Solved Launch control zsolth 4 825 25-Sep-2023, 06:52 AM
Last Post: zsolth
